Oil pan removal
Fjordlander
Kyle
Scottsdale K10
V8
Hello all,
I know this has been discussed but I haven't gotten a definitive answer on my year. I need to know if I need to raise the engine in order to remove the oil pan from my 1976 K10 Scottsdale. The drain plug hole stripped and the rear main seal leaks so I'd rather get in and replace the whole pan and take a crack at the rear main seal if I can.
CountKrunk
ATL
Count
C20 Custom Deluxe 3+3
v8 350
If you slide down underneath can you get access to all bolts on the pan? If so, i would think you could remove it
fast 99
Spokane, Washington
Easy no interference, jack up at frame and let front axle drop for more room. Use 1 piece gasket if available with small dots of silicone at each seam, apply a small dab of silicone or anerobic gel on main parting lines and seal back and ends.
Fjordlander
Kyle
Scottsdale K10
V8
Thank you!
