OEM style Big Block mechanical fuel pump question
Craig 85
Nashville, TN
454/TH-400/NP205
When I purchased my truck it had a an electric fuel pump on it. According the the PO the rubber fuel lines were bad at the fuel tanks (confirmed), but he also said he did not like the clearance of the mechanical fuel pump to the frame, thus he installed the electric pump. Although my truck is an '85 it was manufactured 11/84. The air cleaner also has a 1984 emissions tag on it. I was told the PO replaced the original motor with an unknown year 454. I haven't checked the casting numbers yet though.
I'm going to install a mechanical fuel pump back on the truck as I don't like how the electrical is plumbed. It's too close to the passenger exhaust pipe. On Rockauto and Napa both show a fuel pump for trucks manufactured prior to 1/1/85. Does anyone know why there is a difference? I'm guessing emissions possibly.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
More then likely there will be extra hook ups for newer models. I was gonna go mechanical on mine but didn't want to lift the engine to get the rod back in. It's kinda tight. Well the only way I was gonna get a pushrod back in was to lift it up and I wasn't doing it so I welded a sump in my tank and made it a rear bottom feeder.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
I know that my Caprice Classic is a 1986 model year manufactured 11/85, and it has a returnless, two-port mechanical fuel pump instead of the three-port that they switched to in 1986 for the B Bodies. It would be my instinct to go with the 1984 pump on yours.
A pump from Jeg's/Summit/etc is a good option too. The aftermarket style are a little more compact and usually the housing can be clocked to get the inlet/outlet where you need it.
Craig 85
Nashville, TN
454/TH-400/NP205
Well today I went to install the Carter fuel pump (3port) I got from Rockauto that says its for my vehicle, but I found a problem. It's longer than the stock one. The canister part of the pump on my original one is 1 7/8". This new one is 2 3/8" long. It looks like it will physically fit, but due to the fact it hangs lower, I worry when the engine torques, it my hit the pump on the cross member. The OE pump has an AC logo on it, but I can't find a part number.
Is anyone in the know what part number to look for with the shorter canister? Most the the ones I see on line are the longer ones. I've ordered on into the local Napa store. Hopefully they have the correct one.
Craig 85
Nashville, TN
454/TH-400/NP205
Answer Found:
I picked up my fuel pump from Napa today and from the pictures you can see they provided the correct fuel pump. Their part number is B-0216-P just in case someone needs it. The ones from Autozone and O'Reillys are the longer version like the pictured Carter pump.
Craig 85
Nashville, TN
454/TH-400/NP205
I wanted to give some update info on this fuel pump issue. I had a kncok in my motor after getting the transmission rebuilt, so I took the pump out to rule out that was the source. Currently, I'm getting a new 454 installed and wanted to get another pump from Napa for the new engine. The pump their catalog shows the pump in the middle. When the store received the pump, it was like the one on the right with the part number M60191. In fact, the Napa box now says "Engineered by Carter" and has the same part number as a Carter pump printed on it. Which is the wrong pump for my truck.
The original pump I received from Napa had the name Pierce cast into it. It looks like they have gone out of business due to Cash for Clunkers. If anyone needs this style of pump the correct part number to search for is Airtex #41615. I have found that BWP made a pump with the same number, but they were bought out by Standard Motor Products and the pump is no longer being produced.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
I wonder what the Airtex mechanical pump reputation is. A lot of people won’t give the electric ones the time of day.
74 Shortbed
No personal experience with them myself, but I hear both sides and more negative than positive if it means anything..
jingle1
