NP203 HELP please....
oneluckypops
Sedalia, Mo.
Luke
Does anyone know what the Over all length of a TH350 with a NP203 Transfercase is?
Or what the Over all Length of a 700R4 with a NP241 Transfer case is?
I am trying to figure out what I will have to do for a drive shaft to change from a 350 with a 203 too a 4L60E with a 241c?
I can measure mine next time I am under it and can remmeber to do it.
oneluckypops
Sedalia, Mo.
Luke
lol i can understand the remembering part, hell i have slid out from under a car to get a wrench only to grab a drink light a cigerette and slide back under it then I realize damn i forgot the wrench.
oneluckypops
Sedalia, Mo.
Luke
Actually hell if anyone has a truck that they have a 700R4 with a 241 transfercase maybe I can get you to measure how long your driveshaft is. Mine is a long bed with a 14 bolt FF Rear end and a Dana 44 Front Differential.
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
i can get you both measurements in a bit. my 60E/241 truck is parked right next to my 350/203 truck. LOL
Fairly certian the dimensions would be exactly the same as a 700r4/NP208 combo. I have that sitting in my driveway if you want me to get it.
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
Best to get an actual measurement from DHC or HRPC, the Hollander is giving me conflicting answers.
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
who is DHC?
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
the 350/203 is ~45.5" from the bellhousing to the center of the rear output yoke. the 700(60E)/241 is ~47.5" from the bellhousing to the end of the output shaft seal.
oneluckypops
Sedalia, Mo.
Luke
Your truck that has the 700 with the 241 isnt possably a long bed 3/4 ton is it? If it is could you possably measure how long the drive shafts are from center of U-joint to center of U-joint? Hell if you dont mind could you measwure both trucks drive shafts lengths for me?
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
nope, its an extended short 1500, though it does have a 14SF in it.
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
~60 1/4" for the 350/203 in my 77, though it is a fixed yoke, and the driveshaft has a slip shaft built into it
~64 1/2" on my 94 ECSB, with a slip yoke at the output of the transfer case.
oneluckypops
Sedalia, Mo.
Luke
well crap was hoping your 94 was a Square Body Truck. I am trying to figure out what length of Driveshaft I am going to need if I go ahead and use a 4L60E in my 85
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
your 85 has a 60E in it? should be a 700/208
oneluckypops
Sedalia, Mo.
Luke
I am in the process of putting a fuel injected vortec 5.7 with a 4L60E and a NP241 PS Drop in the truck. Eventually It will have a 4L80E but gotta find another one
scawdrey
