- May 18, 2020
- Auburn, Washington
- Todd
- K20, C10
Welcome !
Stunning Burb!
Stunning Burb!
I just helped my old coworker figure out his periodic misfire on his 289 68 mustang after a 4 barrel swap and I asked if he checked his points gap after he said he set timingIf it hasn't been done already, one quick upgrade is to swap in an HEI distributor from a '75 or newer vehicle. Get the large cap version with an internal coil and only two external wires (BAT power and tach). Its an easy direct swap, and you no longer have to worry about adjusting and replacing points.
For a second I thought I saw a pic of my trailer with wheels In it lolHey everybody - glad to have found this forum. I am new to the square body world though i did learn to drive on a 75 scottsdale back on the farm. But I am an adult in the suburbs now. I purchased a 73 super cheyenne suburban a couple years ago. I performed a few repairs on it that were in my wheelhouse and hired out some work too. My mechanic loves working on this old beast. She's good to go anywhere. Biggest puzzle piece is to locate the elusive rear quarter window seals. Anyhow, looking forward to sharing and discussing. see ya on the boards.
he asked me what are points
I gave him a quick run down and then explained my Buick Electra HEI distributor as comparison and he said “well that’s a lot more convenient”
I asked if he owned feeler gauges and he said no and I said how to adjust /check and he asked “is there a way around that.”
he just bought an Ford performance or something HEI unit and is gonna drop it in lol
after my skidsteer killed a set of points when the coil melted I have a sour taste on them because I just figured it out and bam had to do it all again
I domt personally want to service them that often tho. My skidsteer that’s fine, I’m gonna install a point saver that reduces the arc across the gap to miliamps so I just gotta keep em cleanPoints are fine, and have served the motor industry well throughout the years. At least you can look at points and service them. Just keep the moisture out of them.
no i didnt speak clearly. i asked him, after he had said he set his timing but also has a misfire underload even after that, if he checked his points. Because I knew that part about points he didnt know about the points which is my theory. with how little miles it may damn well be the original set and if it has a nylon block it may be degrading etc. personally i would have inspected and likely installed new points and gapped them and set timing and i bet the issue would be gone.Taylor, you have this backwards. You need to set the point gap to achieve the correct dwell first. Then you set the timing.
Every degree change in the dwell changes the engine timing by two degrees.
Just a bitWhere ya been @Frankenchevy ,new job keeping you busy??
