New to website
KingBee
Marcus
i've been searching the threads for some information and can't seem to find a definitive answer. maybe someone will reply and help.
are there differences in 77-80 instrument lens versus the 81+?
second question: has anyone got a preferred method for polishing the plastic lens on the instrument cluster?
77 K20
Montana
K20 5" lift
HT383 fuel injected
I looked at LMC and according to them the gauge cluster lens is the same part number for 73-80 and 81-87 (P/N 38-8003). But they want almost $50 for it!
I tried polishing mine years ago when I had it all apart. For some reason it is "fogged" and seems it is the plastic itself and not just the surface.
chengny
1. Looks like it depends on whether or not a clock is installed.
No clock - you're good from 73 - 87 (up to 91 for Blazer, Suburban, etc):
(1973-87) Instrument Cluster Face-w/ Gauges w/o Clock
With a clock - for some reason, 80 and down is different than 81 and up:
(1973-80) Instrument Cluster Face-w/ Gauges & Clock
(1981-88) Instrument Cluster Face-w/ Gauges & Clock
Why the presence of a clock matters is anyone's guess - though I'm sure someone here knows. Maybe the earlier model clocks had the time adjust stem in a different location - and the hole in the lens didn't line up.
2. No. Once it has been abraded, nothing (at least nothing that I have ever seen or tried) can restore the plastic lens to anywhere near it's original clarity. The preferred method is to save up and buy a new lens.
ajd89
Central Michigan
andrew
Welcome!
Ive got a few extra clusters i can check and see but from what i remeber the plastic was in pretty decent shape if your interested
animal
Lee
c10 silverado
350ish
:welcome:
Paladin
"Teufelshunde"
Wichita Falls, Texas
C30 Silverado Crew Cab Dually
Welcome from Texas!:cheers:
4WDKC
Southern Florida
Kacy
Position of the knob to adjust time on the clock in a different position? that would cause it to be a different number.
what about the headlight polishing kits anyone tried them? Not the spray on wipe away kits the actually buffing with rubbing compound then polish?
WFO
Texas Panhandle
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
That's a good idea. I bought a mother's headlights restore kit. Came with polishing wheel for your drill and fine wet sanding pads. I used it on my 2000 camaro ss lights and it did a pretty good job. I think it would be worth a shot you might like the results.
chengny
I tried a couple of those polishing kits. I spent hours and hours on a particular lens one time - just to see if it was possible. If you do it long enough (and the scratches aren't too deep), the process will eventually bring the area around the scratch down enough so it blends in to the depth of the scratch. But that comes with a cost; even though the rubbing compound provided with the kit is extremely fine, the plastic - while smooth to the touch - develops an unavoidable slight haze from the abrasion required to level the scratch.
I suppose it all comes down to how picky you are. You can certainly see the gauges through that very mild haze easily enough. But, in most cases, that was also probably true even before you began the polishing process. I am a cheap MF and will do a lot to save a buck, but as far as this project goes...I say either leave as is and get used to it or just get a new lens.
These lenses have dropped quite a bit in price. They used to go for right around $100. Currently, Classic Parts lists all three at $49.95:
https://www.classicparts.com/1973-87-Instrument-Cluster-Face-w_-Gauges-w_o-Clock/productinfo/24-444/
trukman1
USA
Gary
K5 Blazer
5.7 L (350)
Welcome!
Wouldn't happen to have any dash cluster housings for an '88 Silverado lying around that you'd part with, do you?
highdesertrange
kalifornia
mike
k30
I have used plastic polish before, came out fine. however like everyone said, it depends on how bad it is. highdesertranger
RoryH19
Rory
R10 Silverado SWB
I've used Plastic X to polish my lens on various cars along with my R10. It does help but as everyone mentions it depends on how much damage there is.
If you want to take a chance, a fine grit sand paper will help cut the larger imperfections down. EG 2000 grit. Then polish with the plastic paste/liquid.
di11ard
