N00b from SWMO with a slightly unique setup.
86Peter454
Missouri
C10 Scottsdale
hello,
my name is Matt and i just bought an 86 c10 scottsdale.
the truck has a kinda unique set up with a 454 and a nv4500 5 speed.
truck needs some work done to it like the 5th gear just went out the day after i brought the truck home. seems to be a common issue with these transmissions.
hope to learn from you guys and hopefully add to the community.
thanks,
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Welcome nice looking ride some folks are gonna be a bit jealous of your set up. Also your last 3 pics are broken.
86Peter454
Missouri
C10 Scottsdale
yea i saw that. its actually the same 3 pics they just didnt add to the post correctly and i couldnt see to remove them when i edited the post to make them work.
also thanks. not much to be jeallous of just yet. this trans is wack. 1st gear is useless and without 5th working its basically a 3 speed lol.
many mods to come though.
animal
Lee
c10 silverado
350ish
:welcome:
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Cool you are encouraged to start a build thread to document your progress in the Under construction thread
CSFJ
Welcome. Iirc, the nv4500 was really particular about the fluid it ran. From what I understand if it wasn't GM's oem fluid, it caused a lot of problems.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
It don’t run ATF?
CSFJ
It don’t run ATF?
I'm thinking GM ran Syncromesh, or something similar in them. It was one of those things that kind of turned me off on that trans, because you couldn't get away with just trans fluid or gear lube. It wasn't cheap. and you had to get it from the dealer.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
A proprietary blend of 11 herbs and spices huh?
  • Like
Reactions: WFO
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Pretty much.
Ironic how if you don’t use that fluid it bitches up the trans and makes it unwarrantable. Almost like they knew it was boarder line crap and needed an out so to speak
CSFJ
Yeah, it kind of takes the deadnuts reliability out of the manual trans. The old manual boxes, you could almost pour anything into to lubricate it and get away with it. When you have to run a specific fluid though, just to keep it from burning up, takes a lot away. The problem is , that is about the only "heavy duty" manual truck 5 spd. When I had my jeep, everybody wanted the 4500, so they could have the creeper gear and overdrive. I have no idea why they screwed up the design to where it wouldn't run on common fluids without destroying itself.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Is it Getrag or a GM copy?
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
What about the Dodge trucks that had them?
jodygraham64
