- Aug 3, 2010
- Usually not in Ohio
- Andy
- '77, '78, '79, '84, '88
- K5 thru K30
Just brainstorming here, feel free to comment.
My 4x4 Burb currently has a 4 inch lift and the equivalent to 33's. I haven't rotated tires in close to 40K, so the front tires only have about 25% tread remaining, while the rears are about 90% remaining. I've been thinking it will be time to replace the tires before winter. I'm very happy with the suspension setup and have no desire to change it (other than maybe crossover steering).
The rust is also getting out of hand on the Burb. Both fenders are rotting out on the backside and the rear portion of the left fender is basically just flopping around. The rear wheel arches are rotting out and the inner wheel houses are swiss cheese. I do not want to go to the trouble of changing fenders and welding in new quarters, especially since nobody makes the replacement wheel housings.
I'm thinking this Burb is a perfect candidate for a set of Bushwacker cutout flares. This will remove a lot of rotted metal and provide more tire clearance so I can keep the current suspension setup. I'm thinking a 16x12 wheel with a tire in the 37-38 inch range. I think cutout flares look goofy without a wide tire/wheel combo, also wide tires will help keep the plastic flares from getting busted on small trees and stuff.
What concerns me is my current crappy 3.73 gears and a 700r4 tranny. Currently, we drive around in 3rd gear and only use OD while on the highway and it works OK. I'm worried bigger tires will lug it down too much. Maybe it would still work OK, I dunno. I could regear to 4.88's or 5.13's but I've never done gear setup before... but there's a first time for everything.
At any rate, I need to keep the truck street friendly (ish) which means a radial type tire. I also need to tow the occasional car with it. Long trips on the highway and most towing duty will still be handled by the 454 2wd Burb.
Any comments are welcome, and for those who can't keep my trucks straight, it's this one:
