More th350 questions
mcpaddleboat
Alabama
Wilson
GMC Sierra k1500
350 tbi
How can you tell the difference between a th350 and a th350c
74 Shortbed
A 350C will have an electrical plug in the case on the left side.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
Boonie
El Dorado, KS
Brent
not trying to hijack a thread, but did t350s ever have a cast aluminum flexplate cover like a 700r4, or were they all the sheet metal covers?
For the 4x4 Th350, I do believe so just like the 700r4's. If it was 2wd, then it was either tin or plastic.
Boonie
El Dorado, KS
Brent
ok. was there a break somewhere that they did that, or were they all supposed to have the cast cover? I ask because my 74 4x4 has a sheet metal cover, had it from the factory when grandpa bought it in 74.
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
My truck's had a plastic cover... maybe it got replaced a long time back.
BTW, this isn't hijacking a thread whatsoever. It's titled more questions about Th350 right? If the question is about Th350's then it's on topic and not hijacked at all. Don't ever be afraid to jump in on someone elses thread and ask for more detail so long as the subjects are the same. That keeps us from having so many duplicate threads. And we do have a ton of duplicates here.
Not sure when it happened, but obviously later than 74. Now I'm starting to question myelf. Am I thinking of Th400's?
CSFJ
No, I had a '79 k10 in high school, had the cast inspection cover. The rpo sticker also stated it was equipped with what they considered a heavy duty th350. At one point it started giving me trouble, so the one that I swapped it out with ended up with the regular stamped cover. Perhaps the HD transmissions got the cast cover?
Boonie
El Dorado, KS
Brent
I need to start looking for a hd350 if I keep this trans and don't go 700r. still on the fence about which way to go
87R10_Cruising
