Monstaliner
77 K20
Montana
K20 5" lift
HT383 fuel injected
My truck is quickly rusting away. The doors and front fenders are a lost cause at this point, but need to try and save the cab and the bed. The bed started getting some surface rust pits that were coming thru the paint. Started grinding off the paint to see how bad it is.
Tomorrow night my order of Monstaliner bedliner will be delivered. It is roll on bedliner with the grit (rubber chunks) removed so it is more smooth. Since rock chips and tree/brush pin striping are issues with normal paint this should take care of that.
I had ordered a gallon of their silver aluminum chassis saver, a gallon of blue tintable bedliner, and some basic black for the inside of the wheel wells.
I don't need it to look pretty, just need it to protect.
picture.php
This is the color I ordered, and eventually I hope it looks like this. I need to order new doors and fenders sometime this winter then will start on the front half next spring when it is warm enough to apply it.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
77 K20
Montana
K20 5" lift
HT383 fuel injected
Looks nice! Has it been holding up well? I wish I could spray it, but no compressor and no spray gun. Can't afford to run out and buy a compressor right now either.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
the truck is still a project in the works and progress has been slow for awhile.
I have never driven it
just been collecting parts and money for it hopefully it will be the project in the garage this winter.
I sprayed the fiber board top to my tool box at the same time as I did the underbody. and it has held up awesome I toss tools on it and use it as a work bench. and it has not even chipped or anything yet. I also plan to use it in the bed as a bed liner when I get that far.
the under coat gun is cheap do you have any equipment rental places around you. might be able to rent a compressor cheap.
I am really happy with the way it sprayed I wouldn't roll it after seeing how well it sprayed.
cbrodine
NW Ohio
Collin
C25
How well did the bed liner spray gun you bought work, and what kind of spray pattern does it shoot? Did you have to thin the bed liner or were you able to spray it straight out of the can?
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
I did not thin it at all it looks a lot like rhino lining the texture it has
I played with the air pressure until I liked the way it sprayed
it was a undercoat gun I posted a link to the same type of gun in my previous post in this thread
its hard to explain the spray pattern it had
77 K20
Montana
K20 5" lift
HT383 fuel injected
picture.php
The silver chassis saver is very thin- kinda shocked at how runny it was. Now it needs to dry overnight then can put the bedliner on tomorrow morning.
77 K20
Montana
K20 5" lift
HT383 fuel injected
Got the truck done. Pretty happy with it. Should be very durable.
picture.php
slowgo
wa
Blake
V3500 3+3
454, nv4500, 205, 4.56 rp
picture.php
That looks awesome nice job.
For future reference you should look into renting a compressor, my local rental has large engine driven compressors for like 120 bucks a day.
Angelino81
Navarre, Fl
Nick
Hate to resurrect an old thread, how much did it take to do the whole truck?
77 K20
Montana
K20 5" lift
HT383 fuel injected
I tried to find a receipt of when I bought it but can't. Pretty sure it was a gallon. And in all honesty I needed a bit more to go over the cab again.
I was going to just do the bed of the truck with that gallon but saw how much left over I was going to have- so in a panic roughed up the paint on the cab, pulled some trim and did the front also.
Angelino81
Navarre, Fl
Nick
Has it held up well? I'm planning to do my 82. I was thinking 3 gallons for the exterior and bed, and a gallon for the interior of the cab.
77 K20
Montana
K20 5" lift
HT383 fuel injected
It has held up really well. Just like any sort of painting just make sure you prep the surface well first.
I've driven probably at least 2,000 miles on gravel roads with it and am often on overgrown roads. Trees can still scratch a bit- but is way more durable than paint.
Snips71
