- Dec 7, 2010
- Southeast PA
- Paw Paw
- Chevrolet Tahoe LT
- 5.3, 4WD
For 80's/90's era Chevy/GMC mirrors.
There is a torx head located on the bottom of the mirror base cover. I am sorry but my torx tool did not have the size marked on it but it is the next size up from a headlight adjuster size. Remove the screw. There should be a plastic sealing washer under that screw also.
There are steel clips in the top. Just pull the botom of the cover out over the screw tab and push up and it should pop out, be very careful the edge of the cover is sharp and can scratch the paint on your vehicle very easily.
You can swing the cover just enough to access the tension screws. There are two of them. You will need a 10 MM socket on an extension to reach in there and adjust. Adjust tension and replace cover.
