Lowering a 1984 silverado
618Syndicate
Southern Illinois
C30
Duramax
Tetanus has 2" spindles and 3" springs up front, and a flip in the rear. Gonna raise the front an inch because it hits the inners as you turn....
Aj Farias
Adilson
Silverado 1500
Not sure what the limit is, but this is how mine sits. I don't have a notched frame
i like that, but one thing i have to consider and some one mentioned here is, my it is long bed maybe will not look so good if is to low.
Aj Farias
Adilson
Silverado 1500
4/6 you can do without a notch depending on how you plan to use it. Don't buy a kit just get the parts an buy good shocks.
More info here: Thread 'Wanna slam that 63-98 C10/C1500? Lets talk about it!' https://www.gmsquarebody.com/threads/wanna-slam-that-63-98-c10-c1500-lets-talk-about-it.38131/
Any off the shelf cast wheel will fit fine. Don't worry about the offset, tire size is more critical unless your paying big money for custom built 3 piece wheels.
Thank you, ill look this link with time
Aj Farias
Adilson
Silverado 1500
4-5" if you plan on using it as a truck.
6" flip if you don't plan on carrying much weight. Otherwise you'll have to notch to tow/haul more than a few tru
6" flip if you don't plan on carrying much weight. Otherwise you'll have to notch to tow/haul more than a few hundred pounds.
PLanning to use just as ride around town
Scott91370
Burleson, Tx
Scott
Sierra1500
What brand did you go with? Looking just how I want mine to sit.
I was wrong on the spring size (they were 2" but needed 1.5") so I fixed it in my original post. These were the parts I ordered-
1 x​
McGaughys 2.5" Drop Spindles 73-87 Chevy GMC TruckSUV 33154 (MC33154)
1 x​
McGaughys 2" Front Lowering Coils 73-87 Chevy GMC C-10 33128 (MC33128)
FireTruck1984
Michigan
1984 and 1984
born2Run83
West Texas
Justin
GMC - C1500
5.3L LM7
Left Picture (Before any lowering)
Right Picture:
Front: 1" Drop Spring and 1.5" McGaughy's Drop Spindles (2.5" Total)
Rear: 2" Drop Shackles and 2" Drop Hangers for (4" Total)
Aj Farias
Adilson
Silverado 1500
By how manny inch you lowred your truck?
ebob14
