Let's play where are these supposed to be hooked up to??? (Engine bay)
Ghetto
Hampton NH
Pete
4.1 6 Banger
2 things....
Red circle...Where are these supposed to be hooked up to??
Orange circle..Am I missing some vac lines here?? Where would they be going?
Thanks!
Georgeb
Wisconsin
George
K10 Burb Z71
The wires are for the washer pump and the hose barbs are for the washer hoses. Is there an aftermarket washer pump or tank installed on the truck?
MadOgre
NA
NA
NA
NA
NA
Ya good call I bet there is a later model tank and washer installed too. I did the same thing but I ran the feed from the new tank into the washer wiper motor just like stock and used that as the check valve.
That way it looks the same except for the wire missing from the wiper motor but I actually broke the pins off for the pig tail so unless you know you would never know haha
Georgeb
Wisconsin
George
K10 Burb Z71
Never thought of the check valve thing! That would work nicely. Here is whats in the wood hauler for a washer tank. I had to leave the label on :party36:
MadOgre
NA
NA
NA
NA
NA
I didn't know there were RedNecks in Wisconsin ? LOL
Georgeb
Wisconsin
George
K10 Burb Z71
Carb'ed Vortec 350
Redneks is everwear doncha no? I hass me a litle rednek inn my blud to :popcorn:
Georgeb
Wisconsin
George
K10 Burb Z71
Is there a thread on redneck repairs? There should be! You know, use what works or in a pinch to get home......
MadOgre
NA
NA
NA
NA
NA
Ya just google Red Green
Georgeb
Wisconsin
George
K10 Burb Z71
I used to watch that every time it was on! I have seen some Red Green stuff applied in real life too!
MadOgre
NA
NA
NA
NA
NA
I like the propane conversion the best but I cant find it on you tube lol
MadOgre
NA
NA
NA
NA
NA
I thought it was only broadcast in Canada???
Ghetto
Hampton NH
Pete
4.1 6 Banger
Circled in orange is the pump for the washers. Everything works as it should. Some stuff is still plugged into that black box with the wires cut so I guess I can't remove any of it?
Carb'ed Vortec 350
A guy from high school had a truck that ran on both pump gas and propane. We would be driving around and it would act up, so he would switch it over from one fuel sorce to the next and we could keep on trucking. Later it would happen again so he would switch it back over to the other fuel source. It was wierd but the truck ran fine until it decided it wanted a different fuel source.
millernf
