key ignition replacement
77scottsdale1
Scipio Indiana
michael
k20
with my truck it has a keyless ignition does anyone know how hard it is to replace and how much?
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
What are you wanting to replace, the lock cylinder?
yevgenievich
Viktor
sad
very sad
less sad
Probably the lock cylinder with new key, using steering removal tool, remove the steering wheel. Then would need to remove the turn signal cams. From there you should see a set screw that holds the cylinder. I believe you still need a key to rotate for removal.
77scottsdale1
Scipio Indiana
michael
k20
well crap the original key is broke off in the door:gr_guns:
yevgenievich
Viktor
sad
very sad
less sad
Door and ignition keys should be different. If it is very wore, anything can turn the existing cylinder. Screwdriver,knife, other key etc...
Georgeb
Wisconsin
George
K10 Burb Z71
If you can turn it to start it you can turn it to remove it.
88SQDRW
