Is this a good deal on a set of heads?
Ypsik10
Ypsilanti mi
Chad
Did not want to overpay..
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
What is this for? Your '79 K10? The "no acc holes" would be a deal breaker on a truck that new unless you don't plan to run more than an alternator and maybe PS pump. My brother paid $300 for a set of pretty fresh 350 camel hump heads with accessory holes, which I'd say is a good deal.
MikeB
North Texas
Even if you could get by with no accessory holes, I'd make the deal contingent on them passing a magnaflux test for cracks.
Ypsik10
Ypsilanti mi
Chad
Don't they make diffrent brackets for heads like these I wanted the because they are 64 cc combustion chambers..
MikeB
North Texas
Yes, Alan Grove Components and other companies make brackets for early heads, and are mounted to water pump and exhaust manifold/header bolts.
http://www.alangrovecomponents.com/Small_Block_Short_Pump.htm
Unless you just gotta have chrome or aluminum brackets, I highly recommend Alan Grove. They're not low cost, but they fit well and come with excellent instructions. I bought their power steering pump brackets after wasting my time and money with some cheap Chinese brackets (sold under at least a half dozen "brand" names) that were total junk, from the poor fit, to not working with a 2-groove pulley, to cheesy soft bolts.
Rusty Nail
Rusty
350sbc
Obo?!
Ok.
Does your target vehicle have an A/C compressor in it? That's largely all the "accessory" holes are for? The P/S bolts into the block, right? First year for A/C was '66? The alternator bracket too or does that long bolt go into the head? I think it does but that wouldn't stop me. Get an older bracket...
Either way, there's some way around that! The opposite of the wrap around bracket that uses the manifold bolt in rounded line trucks is easy enough to fab. **** man, we'll figure it out!
Seems like a damn good deal to me @$350!!
Or!
Dude! Why run that hooptie junk?
That's 50 year old technology brah. Just get some vortex for that much, - you'd make more power ! Plus vortex has accessory bolt holes!
SkinnyG
Canada, eh?!
G
C10 Silverado
350/TH350
The pic looks like they used an abrasive surfacing disc to clean up the head surface. In which case - those heads will need to be machined properly before using them.
gmachinz
Harnessworx Inc
Iowa
Jabin
I had a set of 461's on a 350 once. Compression was just over 10:1 so it was sensitive on fuel octane. 2.02 461 heads were 64-69 only and were used on 350 hp 350 engines and 375 hp 327 engines.
Rusty Nail
Rusty
350sbc
I found a set, fresh rebuilt 461s.
Sooooooo, now I'm more interested in the brackets.
Gonna leave some links here for future reference ;)
This article told me what is wrong with my current pulley system, that has a handful of Corvette parts tossed in it!
http://www.superchevy.com/how-to/49718-small-block-pumps-pulleys-brackets/
Something I've read that may help a GREAT deal in our search for brackets....Heads without "accessory holes" were used on motors that ran a SHORT WATER PUMP. Eff! That switch was in 1969 and a lot of our square body accessories switched sides.
http://www.jegs.com/i/March-Performa...20122/10002/-1
o_O.
Look into that long enough and you'll find the name ALAN GROVE. He's got a $91 A/C bracket for LWP that is the only one I've found - so far. There is no way in hell I'd run a Rube Goldberg lookin belt like that though!
I see that air cleaner and hear horsepower dying!
MikeB
North Texas
The Vintage Air system on my 69 C10 used essentially that same bracket, but on the passenger side. It never gave me any problems, even w/o an idler pulley.
Rusty Nail
Rusty
350sbc
Ooh!
Vintage Air, that's a good idea, thanks @MikeB.
The heads I was after got sold today.
$225 fresh built 186s....
gmachinz
Harnessworx Inc
Iowa
Jabin
Ooh!
That's dirt cheap for 1969 Z28 factory heads-damn.
scawdrey
