Interment lights
Randy Terry
Shaky
Going to change standard instrument light bulbs too LED bulbs I was thinking about using the cool White, wondering if that would be too bright? Has anyone change theirs.
Some LED replacements are polarized, some not. If one doesn't work, it'll take out the entire lot.
You can forget dimming them. They are a current driven device, not voltage. They'll either be on or off.
Cool white will be fine.
4WDKC
Southern Florida
Kacy
They were installed in my truck when I bought it, its a nice upgrade just dont use them in your CEL,Brake or turn signal lights they will be annoyingly bright,
Big Chip
Michigan
Kevin
C35
Check Engine Light
Randy Terry
Shaky
Why should I not put them in the blinkers and check engine light? Just asking
Big Chip
Michigan
Kevin
C35
I believe @4WDKC summed it up.
78C10BigTen
pennsylvannia
C10 BIG TEN
I put the 6000k white leds in all my dash lights including my aftermarket tach and heater controls. They wont be too bright. Might be the kind i used but i wish mine were brighter still
Randy Terry
Shaky
What brand did you use?
Randy Terry
Shaky
How many bulbs will I need, I was thinking about 8 would that be right? Oil temp, clock, voltage, water temperature speedometer, gas gauge and High Beam lights.
Randy Terry
Shaky
Can't count too good I think that would be 7
78C10BigTen
pennsylvannia
C10 BIG TEN
I bought mine from ebay. No name chinese jobbies. 20 of them for $7. Idr how many i used because i changed them all... turn signal indicators, the dummy lights such as brake, the wiper and heater control.
87R10_Cruising
