Im stumpped
It was still called a Blazer then. Tahoe name came around '95 or '96, to go along with the new Tahoe 4-door.
Now hold on just 1 minute. I think the Blazer stayed Blazer for a year or 2 even after the 4 door came out called the Tahoe. Then later, it became 2 door Tahoe or 4 door Tahoe. NO? Be interesting to nail down though. You could be right, maybe they did both at the same time, but I was thinking GMC did Jimmy, Yukon, then Yukon XL became the GMC Suburban, where as used to, both Chevy and GMC shared the Suburban name. All that changed right in there togehter in the mid 90's IIRC.
I gotta run, so I'll let you research that and find out for us Andy. :sumo: I'll expect the facts when I get back around 10pm Central time. :grd:
:signs8::signs8::signs8:
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Yep, That's Not a Squarebody. That's the GMT400 Bodystyle. Same exact powertrain you just got rid of though.
So is it a blazer or is it a Tahoe lmfao its cheap and has new motor and transmission that all work flawlessly and he is gonna smog it before I buy it
Your still welcome here though.
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
I hope so cuts the heart an should of that truck is part square body plus its still a Chevy blazer lmfao
He is??? :eek:
:laughing1: Yeah, you're welcome here, just expect some **** from time to time for giving up on your Square, even though we udnerstand, you do what you have to do to get by and make things work.
Yeah, close enough, just a step down though since you now have a ***** independent aluminum housing front axle. And you thought a 10 bolt or Dana 44 front was weak???
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
Well see the plan is to swap that IFS junk out and put a mans front axle in its place because going rock crawling in an IFS truck is like having unprotected sex I just won't do it lol
The other nice thing about Straight Axle in place of the IFS axle, is the natural lift you get out of it. So be prepared for that. You probably won't need a lift kit for the front, but will have to do something in the back to level it off.
Yep, I was always told to leave the house with protection cuz you never know who you might meet.
attachment.php
MrMarty51
Eastern Montana
Martin
attachment.php
I left the3 house without protection once,I had to use one of them things on them invasion of them crabs.:help::roflbow:
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
Shackle flip in the rear is my plan for that I'm a welddr fabricator so I know I can make it work lol
I think it became Yukon XL when the body changed in '00. I'll bet 5 bucks Retro knows all of this stuff and can say for sure.
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
So from what the badging I can see when I looked at it better it is a Tahoe and the reading I've been doing say the Tahoe brand started early 92 as a trim package and after looking at the door tag again it shows 9/1991 which would make it a 92
I know by the body style it's a 92 or later. It's for sure a GMT400 bodystlye and not a square that ended in 91.
C'mon already I wanna see this truck! :Sumo:
:popcorn:
As a trim package, yes. My '91 S-10 is a Tahoe too.
Andy-14
