How to fix loose gm steering column
Chiller
Nj
Quinn
Subscribed for info
hmmmmmmm, I wonder who the Mod was that made this a Sticky and didn't add Meta Tags to it??? :shrug:
:nono:
Can somebody here tell me how to remove the cruise control switch off the stalk to replace?
Ok, it just pops out. I am making a video for this thread.
:laughing1: He said Nipple !!!
Rep'ed it up !!! Others SHOULD do the same. :waytogo:
Thank you, this is a multi video series.
73-91 GM Truck Column Teardown 2 - Locking Plate/Cancelling Cam/Turn Signal Switch
[yt]yrME1iPJ9dA[/yt]
73-91 GM Truck Column Teardown 3 - Ignition Lock Cylinder and Upper Housing
[yt]i8CXEwemYKk[/yt]
:laughing1: :happy175: It's a bitch filming and using tools at the same time isn't it? Cracked the phuk up when the horn beeped.
1984-91...1973-83 are quite different.
Jep, they sure are. The 83 and earlier, NOT have the Multifunction Switch and being totally round. Then the 84 having the MFS and the added little square housing area.
Thanks for the clarification friends. Helps this site stay on top. :handshake:
83K5guy
Corpus
Justin
K5 Blazer
Nice right up
HAHAHAHAHAHA. :roflbow:
Column Vid 3 - Locking Plate, Turn Signal Switch, Steering Shaft Bearing
[yt]Sp5lURpXviM[/yt]
Column Vid 5 - Central Housing Parts Discussion
[yt]CNlnKVJatX0[/yt]
MikeD
