Frankenchevy
Proverbs 16:18
- Jan 3, 2018
- USA
- Jeremy
- Square
- CUCV
- Small
truck currently has two 20 gallon tanks, valve looks crusty. converting to efi, '87 tank/sender, ep381 pump
i purchased a spectre replacement tank for an 87 and the above said parts. this only takes care of one side. since i already have a 9 or 10 psi electric frame mount fuel pump laying around...is it a horrible idea to also buy a mechanical style 20 gallon tank; and just transfer from it, into to the high pressure tank when the high pressure tank is running low?
thinking of places to refill into…maybe 'Y' into the efi systems return line and install a directional valve in the efi return line between the 'Y' and efi? do fuel rated directional valves exist? not sure if the back pressure would affect efi. maybe t into the filler neck?
any thoughts on this ridiculous idea? it'd be nice to do away with the fuel selector and replace the on-on toggle with an on-off toggle for the 12v transfer pump. i'm not even sure how the selector would work with 60psi coming through it. it'd also be nice to simplify the relay setup for the ep381, as well as the main fuel supply/return to the efi.
by the way, i'd just flick the 12v pump on when stopped and watch the gauge then turn it off when it reads almost full.
