Heater core replacement
crusin242000
Vivian
C-10
I have now decided to replace my heater core. Simple and near completion. I have one question. Should I use some kind of adhesive on the firewall? I have the inner fender out so it will be easy to access the bottom bolts . Thanks in advance . Really a good group of knowledgeable guys on here.
yevgenievich
Viktor
sad
very sad
less sad
If the engine bay side of the hvac stayed in place, should not really need to add anything
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
On the engine bay side use 3m strip caulk. I just did a heater core on my suburban. I used foam tape on the inside and I did a little extra and put some regular silicone around the inlet.
I've moved this to a more appropriate subforum
crusin242000
Vivian
C-10
It was taken out by a shop(hvac) what should I use to seal that opening ? Thanks
yevgenievich
Viktor
sad
very sad
less sad
As was mentioned strip caulk, silicone and foam tape depending on exact sealing surfaces would work.
I had used just silicone and foam tape before just to get going with ok results. Strip caulk is the correct way to seal around on the engine bay sides and where evap core lines come in.
crusin242000
Vivian
C-10
Okay . Just received the 3m strip caulk. Preparing before I start reassembling. Does anyone have recommendations on the fasteners? The nuts that came from the factory are almost all dinged up and not reusable. Should I go stainless or any suggestions would be greatly appreciated here. Thanks
Snoots
Roger
Jimmy Sierra
Zinc coated should be fine. Splurge on SS if you like.
crusin242000
Vivian
C-10
Okay so just a regular washer or maybe a lock washer ?
PrairieDrifter
North Dakota
Mason
As long as the studs are still on the heater box inside you’re fine. A flat washer will do just fine, I like to use lock washers too, but that’s just me, you don’t really need them for this job
crusin242000
Vivian
C-10
Thanks! Do you know what size nuts / thread pitch to buy? Hate to ask so many questions, but you guys sure help me out !
PrairieDrifter
North Dakota
Mason
I believe it’s 1/4-20
radio2000
South Carolina
83 and 88
83 C10 and 88 R10 Burb
Does anyone know of a step by step on how to replace the heater core?
My 89 Burb is in need...
Sent from my SM-N986U1 using Tapatalk
1975K20
