Function testing factory Gauges.
How about a jumper cable right to the head from batt ground, just to see if it makes a difference?
Never mind, saw you ran that jumper ground, and it still didn't work, that's fugged up.
Jup, Clamped a 10ga wire to the hex of the sender and then to batt negative. But you know, it could be it needs the same ground chassis ground that the gauge is using. I never thought of that. I should have tried grounding to the firewall or frame. I dunno, I'm doing the Big 3 anyway for other thngs like off road lighting, a big power inverter so I can run power tools off my truck, and a small winch for lifting motors, and adding a dual batter system too. Hopefully, I get all that done, if it is ground issue that will be resolved. If that doesn't do it, then I'm convinced it's the printed circuit, which I could confirm by Chegneys suuggestin by testing at the pins of the cluster. Taking his suggestion 1 step further, I"ll aslo test at the cluster plug in. If it is not good there, then I know the issue between the fuse block and the plug. If it is good there, but not good at the gauge pins, then I know for a fact it's the printed circuit.
Almost as if the gauge is searching for a signal and can't find it. :shrug:
sonicbluezx3
North Carolina
Steven
Who says you cant make aftermarket gauges look stock?
I've seen it done before with Steward Warners. Deluxe Series.
sonicbluezx3
North Carolina
Steven
Sorry those pictures suck.... came from my iPhone. I'm going to try to take some pictures with my real camera today. Putting the finishing touches on the interior today.
CmuCmu
