Fuel system choice for new 350 crate engine for 87 blazer
74 Shortbed
Right on. Weber it is then. I drove a 67 c10 a lot of miles with a 350 1 barrel a ton of miles.
Correction: 2 barrel.
I had a 63 Biscayne with a 283 and 2 barrel, it did run good and reliable, lol..
roundhouse
atlanta ga
justin
77,78,79,80 ?
I actually like two barrels
My 71 Firebird has a stock 350 with a 2bbl and it would absolutely fly
My 74 bronco had a 351W 2bbl and was plenty of power
Best thing about a 4 bbl is the SOUND
nothing in the world sounds better than a 4 bbl on the floor
Big Chip
Michigan
Kevin
C35
How about I help you out on the next one.. I'll hold back and you can turn loose.. :cheers:
You’re a real pal if you’d do that for me.
K5Blazerboy87
Tacoma Wa
Kyle
K5 Blazer Silverado
So are the holley tbi good? do they even make the proms for ecm and stuff Idk I was just thinking about swap to carb better performance and reliable if is it easy the swap im not useing tbi 350 id just get normal 350 crate I want some horsepower but I want something reliable.
4WDKC
Southern Florida
Kacy
If you havent connected a laptop to the truck to figure out what is wrong with the TBI or aren't willing to just put a carb on it. You will need to connect a laptop for the stock tbi and unless you buy an aftermarket with a hand held programmer you will still need a laptop.
bman1985
Maryland
Brendon
c1500
I replaced my qjet with a summit brand 600 on the 350 on my truck.I drive it maybe twice a year. Sometimes pulling a boat. It runs great starts every time 100 degree summer day, 20 degree cold day doesn't matter. Just have to adjust the idle speed depending on the season. I'd consider it very reliable and trouble free.
TBI is good too if you can iron out your problems. Engines last longer with EFI.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Ok maybe I’m way off here but how does EFI make an engine last longer?
CSFJ
You see? You're gonna regret all those nasty things you said about TBI. lol
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Ok I thought I missed something.
people say excess fuel from carb(can't be perfectly adjusted for all parameters) causes fuel wash on cylinder. just one reason I've heard. I have seen in a couple shows and magazines who've pulled different setups apart after some miles say the efi stuff has less ring and bearing wear from less raw gas in the cylinder. supposedly, all other factors being equal, having optimal AFR will prolong engine life. I couldn't say either way as I just learned my ass from my elbow recently. I'm still not 100% on it.
K5Blazerboy87
Tacoma Wa
Kyle
K5 Blazer Silverado
Code 42 electronic spark timing idle weird I gotta barely put my foot on the gas to start on old starts but ethier or I'm putting new motor in it but how do I connect lap top to it? With it being obd1?
74 Shortbed
If you're washing down cylinders with a carb, you either have a phuckd up carb or a very unadjusted carb, or both. :D
Garcjay
