Froze BBC
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
or build an engine stand would be kind of handy to have
Just make a quickie one that's low to the ground and wide based out of 4x4s and strap the engine to it to run it atleast threw a heat cycle.
ajd89
Central Michigan
andrew
Start it before installing.
Duh! Why didn't I think of that! I could just put it back in the frame...only issue with that plan is I can hook up the fuel lines and pump and I've got the exhaust still can prob make that work good enough even with the busted bolts. But I'd need to get a radatior I scrapped all the ones I had and I'm not sure how it would work with the TBI I have the computer and the whole wiring harness I guess I could figure it out I have some manual gauges I could hook up to.
First time using this multi quote let's see if it works
74 Shortbed
This is my running stand 3 sections, when I'm done I just hang it on the wall out of the way, note the neighbor friendly exhaust system, LOL..
ajd89
Central Michigan
andrew
Thats pretty sweet! How loud is it? At least you have mufflers on it. To bad mines tbi I feel like I'm gonna have to hook that all up to get it to run for a decent amount of time
74 Shortbed
Thanks, they're just cheapo turbo mufflers but they're not bad, I never had a complaint while breaking in a cam for a half hour, lol.. Nice thing about it you can work on it, you can take it down to bare block if you have to.. Just to run it on the stand I wouldn't mess with that TBI ****, just throw a carb and distributor on it, put the TBI on when you drop it in the truck.
ajd89
Central Michigan
andrew
Ya i don't got one ill have to hit up gramps he probably has one I can barrow then an adapter for the tbi to carb and a fuel regulator should be good
1980Spartan
Seattle
Mark
C1500
This is legit. I'd just hit the like button, but it deserves some more recognition. Well done!
da_raabi
Trailer Park Supervisor
FloriDUH
Adam
c30
Man you are over thinking things. Plop the engine into the frame, use a couple exhaust flex pipes to get the exhaust away from you, run a water hose to a heater nipple and use an old shop vac hose to pipe the water OUT the water pump INLET, run a couple fuel hoses from your pump into a little 1 gallon fuel can and fire it up! Did that with the 454 I pulled out of an RV for my Camaro... Worked damn good too!
Daveo91Burb
Vancouver, WA
Dave
V2500 Silverado Suburban
Vortec 383, modified TBI/4L80e
Last page or two of my engine build thread has details of my home built run stand. Very simple, no cooling, muffling, permanent fueling system (gravity fed!), or gauges except oil pressure. Pretty ghetto to build a run stand out of 2x4s and 4x4s I know, but it works and it's rock solid. For cooling I just poured water down the water neck until it came out the water pump holes - I'm only running it for a minute or so at a time.
http://www.gmsquarebody.com/threads/383-vortec-tbi-build-thread.17772/
CSFJ
Could go really low buck.
Fwiw, the rest of this video series shows some real old school methods of getting an old engine running again.
ajd89
Central Michigan
andrew
I will check it out. Yea prob be easier if it was an old carb motor that's forsure but being the tbi it's gonna take a little more. I like the garden hose idea tho if you don't got a radiator. Id like it to run for a bit not just spudder on some gas down the intake. Thanks for all the great help hoping after hunting season to figure out what's up with it.
Jack253
