Ford NP208 Interchange / 27 Spline Output Shaft Th400
MadOgre
NA
NA
NA
NA
NA
Just noticed that it only has provision for the stamped tin torque converter cover. So its not a factory 4wd unit.
silverscottsk10
trafalgar indiana
mike
That irritates the hell out of me too, the tin won't stay tight and rattles like hell
MadOgre
NA
NA
NA
NA
NA
Ya the factory 4wd unit is nice cause the cover has 2 torque arms that go to the engine mount brackets
silverscottsk10
trafalgar indiana
mike
It had a 305 from the serial number, but he'll idk what's stock on this truck
silverscottsk10
trafalgar indiana
mike
I'll have to dig up the receipts the po gave me on the transmission rebuild. I'm curious to see if there's anything mentioned on it
silverscottsk10
trafalgar indiana
mike
Found the receipt,
"Turbo 400"
1 master rebuild kit
1 rebuilt torque converter
1 front planetary
1pump body w/gears
1 direct drum with sprag
Vacuum hose
Nothing mentioned of the shaft
Stewzer55
Ohio
Stew
R30
Interesting stuff, possibly included in the Master Rebuild kit?
silverscottsk10
trafalgar indiana
mike
Well I guess I'll get rid of the truck soon if I can't find even a matching trans/tcase I can afford
Looked everywhere and called every junkyard around, they either don't call back or are idiots and want 500$ for a tcase
I'm wore out from class and work and need a vehicle I don't have to share, I don't know if I can go another two months without one with the gf gettin a new job and classes changing
I'm in a hole and my ladder was stolen...
Hold off, and set it aside. One will show up. These things go in spirts. Not long ago you could pick them up all over for $50. I had 4 at one time, now down to 2. Sold 2 of them for $100 ea a few months ago. I kept the one for my A833 and one for my 700r4/Th350.
Just a tip, you might change your location to include the state. I have no clue where or what trafalgar is. You might also post a WANT AD in the classifieds.
mattyb
