Fenders or Front Clip
Georgeb
Wisconsin
George
K10 Burb Z71
I do like that creeper thing and think it would be very useful provided it didn' restrict how far you can reach.
Mid 70 to mid 80s is the only era of Ford is ever consider owning :)
Burban
Bear
Uranus
H
Suburban
-- DISSASEMBLY --
* all parts are 81-87
  1. remove the hood
  2. remove the bumper and brackets
  3. remove the battery
  4. disconnect the wiring harness from the headlights, horn, ground point, etc.
  5. unbolt the radiator from the core support (don't miss the two bolts on the bottom)
  6. unbolt the fenders and inner fenders from the cab
  7. unbolt the core support from the frame (the body mounts) (will have to remove grill to access them)
  8. remove the front clip
This was the thread I had read, he seems to have kept the radiator on?
Taking everything else off so if it's me I take that off as well :shrug:
Georgeb
Wisconsin
George
K10 Burb Z71
Thats the safest way to do this so it doesn't get damaged. I had a hoist to lift mine off so I left the radiator in it. But it is up to ones own discretion.
robert8096
Goose Creek SC
Robert
If you have AC the condenser will also need to be disconnected or removed from the radiator shell
Keith Seymore
Motor City
Keith Seymore
4.3L
Either that, or get one of these fancy creepers.
Very creepy.
But the ladder thing is kinda cool...
K
Burban
Bear
Uranus
H
Suburban
Bugger, starting to sound more complicated, maybe I should just pull off the fenders?
Not that complicated IMO you pull of just fenders then you'll deal with realigning fenders and that can be painful if you've not done it before
MannyDantyla
Lawrence, KS
Danny
sbc350/sm365/np205
Yeah if I was doing any work on the engine I would have removed the radiator, but I was just swapping front clips so no need to waste all that coolant. So I just kept the radiator connected to the hoses and leaned it gently against the fan. (When I was working on the engine earlier this year I literally crawled inside the engine bay and tried not to step on the brake lines or anything. lol)
It was a lot of work, needed three people to pull the clip off. I installed the new one piece-by-piece but you won't need to do that, just take it off in one piece and put it back on in one piece.
Here, watch this and the next video in the series:
https://youtu.be/4khAIx6v70A?list=PL-5YzBia-1blLShB8-StTZerjEObtJny3
I love that youtube channel.
Georgeb
Wisconsin
George
K10 Burb Z71
If you are planning on doing heads ans intake why not pull the engine and do that work on a stand? There will be plenty of room then to sit in the engine bay and fix stuff up.
Skweegle89
Oklahoma
X2. You can have that motor out in no time. You will be pumped when it's on a stand. Then you can clean it all up and repaint it, as well as clean up your engine bay.
MadOgre
NA
NA
NA
NA
NA
Xxx3
CmuCmu
