F250...Front Shock Mounts
8T6K5
AZ
L98 350 TPI
...ha, got all of you to look.
Seriously, is anyone in here using the Ferd F250 front shock mounts on your Chevy?
This might actually only appeal to just a few guys in here, but Im looking for some feed back.
Seems like a good diy and want to order this stuff up (front only).
Will do the rear inboard mod afterwards.
http://coloradok5.com/ranchoreview.shtml
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
Neat mod, I'll be looking into this! I need shocks all the way around anyways.
wheelerboy12
Dundee, OR
jeremy
i had f250 mounts on my old square with extended travel shocks, helps a lot, i would recommend it to anyone, its especially good at stock height increases your flex almost 3 inches... good luck!
Usually when folks install those, they have them mounted ahead of the brake hose (more upright) and a little more material is left on the shock mount. The one in your pic has the entire bottom half lopped off. Still looks like a better setup than stock though.
wheelerboy12
Dundee, OR
jeremy
the guy i bought it from did it that way, not ideal but still much better!
Yeah, it looks like it allows for a shock that's about 3 inches longer. Every little bit helps.
8T6K5
AZ
L98 350 TPI
OK so this project is a go.
Put the duals on CL last week, amont other things. Guy who bought the "kicker" shock mounts now wants my front duals.
Ordered up the new shocks today, should be in Wed. Going from 7.875" to 11.25" Shopped local dealers for the mounts. Fawkers are thieves! Biggest dealership wanted $30 ea! Found another one close asking $17.50...and they were the only guys who had more then 1 in stock anyway. Will be picking those up tomorrow.
Guy is comming over Sun to take the old shocks and I will get on the the install....
Also have the ORD Zero-Rate leaves/blocks to throw in too.
http://coloradok5.com/ranchoshockreview/frontshockremoved.jpg
http://coloradok5.com/ranchoshockreview/fendercut.jpg
http://coloradok5.com/ranchoshockreview/f250installed.jpg
http://coloradok5.com/ranchoshockreview/f250angle.jpg
http://coloradok5.com/ranchoshockreview/frontshockinstalled1.jpg
Hope to end up with something like this.
http://coloradok5.com/ranchoshockreview/shockdroop.jpg
8T6K5
AZ
L98 350 TPI
Holy Sheet these things are stout.....
My guess is about 2-3lbs ea.
Will need to chop about 5" or so off the bottom and will secure them to the frame with 3 bolts......
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
What kinda pricing are you guys getting on these? I'm a Ford parts manager, and may be able to match pricing, and my UPS prices are cheap too...
wheelerboy12
Dundee, OR
jeremy
couple bucks at the junk yard....
8T6K5
AZ
L98 350 TPI
$16.50 from a local dealer here.
Ill spend the extra $12 to not have to scrounge - pull my own and have new ones.
chevydude
arizona
hunt
k20
where can we buy these shock mounts.
8T6K5
AZ
L98 350 TPI
Your local Ferd dealer, ORD, eBay.....
Call around though, pricing in Phoenix was $30-$17 per. Like $45 for the set from ORD.
8T6K5
AZ
L98 350 TPI
1986K30
Colorado
Sam
7.4L
Turned out great. Cant beat the payoff in additional flex!!!
BrianGarf
