Engine swap questions
87silveradok20
Ohio
Levi
Silverado k20
I have yet to see a thread exactly like this so I figured I’d start it. So this winter I am going to swap the motor in my truck. The truck is an 87 k20. I’ve narrowed down what I want down to 3 options. 1) crate 350 or 383 with aftermarket efi, 2) 6.0 and 4l80, 3) Cummins with dodge overdrive trans. The truck is just a driver and will occasionally pull a trailer but not a huge one. If I go with a gas motor I will probably get 350-400 hp out of the motor. If I go Cummins I probably will leave it relatively stock and just turn it up some. I want it to have good road manners and I don’t have a huge budget to do all this. So what would you do and why.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Cummins is probably cheaper then a good crate engine and FI. And well it's a Cummins is why....but I'd mate it to a 4L80 not a Dodge transmission.
87silveradok20
Ohio
Levi
Silverado k20
Do you think a 4l80 would hold up to the low end torque?
yevgenievich
Viktor
sad
very sad
less sad
program to disable shift to 4th gear at wot and it should be fine with a relatively stock cummins.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
And with the Cummins a little fuel plate massaging is all you'd need for a cruiser light tow rig. And what Viktor said
87silveradok20
Ohio
Levi
Silverado k20
I actually would probably go with a ve pump unless I got a good deal in a p pump motor but yeah same concept essentially.
87silveradok20
Ohio
Levi
Silverado k20
If I wanted to build the transmission down the road would it be cheaper to build a 4l80 or a non electrical dodge trans to hold the same power.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Dodge doesn't have a very good track record with automatic transmissions. Can they be built up sure but with a 4L80 you get the proven dependability of a TH400 with OD.
87silveradok20
Ohio
Levi
Silverado k20
Trust me I know plenty of people who have had trouble with dodge transmissions. I have heard tho that they can be made very reliable. I’m not trying to diss the 4l80 I just wanna make sure I can get a good idea of what’s the best option for me in my situation. I also understand if I asked which trans is better on a dodge page they would all say the dodge trans.
4WDKC
Southern Florida
Kacy
I must be living in the wrong place, 200k mile 6bts are 2-3k here without a transmission. Based on how little you will be towing it depends on the cost of engines in your area. For example for me
3k 6bt +transmission + tcase(?)+ odds and ends
2k crate/rebuild + 1k efi + odds and ends
$800 6.0+ 500 4l80e+ tcase(?)+ odds and ends
I left off the things that would be common between all 3 liek exhaust work, fuel lines, etc. I am usually not a LS swap fan but when coming from a carb setup its hard to beat the budget junkyard swap.
4WDKC
Southern Florida
Kacy
NV4500 problem solved?
87silveradok20
Ohio
Levi
Silverado k20
You think the way I do. Let me modify your list a little so it’s closer to what things are like in my area and how I would do it (maybe).
1st gen Cummins (full truck) 5k+ odds and ends- selling rest of truck
6.0/4l80 $1500+ transfer case adapter
Crate $3500+ $1000 efi
My prices are probably a little higher than what they actually would be. But they should be close.
87silveradok20
Ohio
Levi
Silverado k20
There is that too. Or dare I say Allison....
Slow down now. I don’t have that much to throw in for this project. Maybe some day tho...
rowdy_80
