just_some_guy
- Jan 20, 2021
- Georgia
- Barclay
- K5 Blazer Siverado
- 5.7L
OK, so I am planning on replacing the gauge cluster that is currently in my Blazer with an "updated" "custom OEM" version that has a clock and a trip meter. I already have all the parts to do this. I just finished replacing all the bulbs in the new cluster, too. For the 5 display bulbs I used amber colored LED's and for the 7 other bulbs I just used some new incandescent ones.
Anyway, I am going to have to use a hole saw and drill to cut a hole out in the back of the white plastic housing for the clock. This shouldn't be a problem.
The real issue I think I'll be running into here is gonna be with the crystal. I gave up trying to find one with BOTH of the holes for the clock and trip meter, so I ordered a new one without any holes at all and decided to just "make my own" holes. The problem I need advice on is how to properly mark where the holes go and how to make the holes. I thought about using a soldering iron to melt them, maybe?
As for marking where they go, I have one crystal with a hole in it already for the trip meter. I just figured I would lay the crystal with the trip meter hole on top of the new crystal and use the hole to mark the other crystal where I need to drill. That should be OK. The real problem will be locating where to put the hole for the stem used to set the clock.
Any advice on how to mark the clock hole and how to drill both of these holes in the plastic crystal will be greatly appreciated. I don't want to screw up this new crystal.
Thanks!
Thanks!
