- Jul 3, 2012
- Right where I am
- Bagoomba
- 81-C20 Silverado Camper Special-TH400-4.10s
- Carb'ed Vortec 350
Just finished up a trip with the truck that clocked about 1,300 miles and the truck did great. Camped 4 nights, and was able get some of my sanity back by breathing cool-clean-mountain-air. The current engine is definitely underpowered for some grades, but it ran well and kept up with traffic doing 70. It fought me tooth and nail to get it finished for the trip and the departure date was postponed a day because of that. Part of the fight was the temporary exhaust sytem. Got it installed, bolted the right rear tire back on and the pipe hit the tire. The D60 must be a tad wider than the HO70 that is currently in this truck. With the temp-exhaust installed I at least fired up the truck to hear it. It ran smooth. Shut it down right away so I didn't burn my new tire. So I ventured over to an auto parts store and got some exhaust elbows to divert the heat away from the RR tire. It worked, but it is ugly. And it made the truck much louder than it was with the pipes exiting behind the tire. The new stupid exhaust system, had to cut it in two places to get the front portion removed. I swear that guy that did this new system is either a moron or very inexperienced. One-The exhaust system was not at all able to be removed because it hit the lower suspension control arms. Two-He cut my bell housing mount cross member and hammered the pipe flat on the top side to get it to clear the cross member instead of utilizing the factory high spot of the cross member to run the exhaust pipe under. Three-As I mentioned before, the pipe from the passenger side is way too close to the brake lines and front cross member. Four-He used pipe bigger than 2 inch for the pipe mounting to the exhaust manifolds. I told them I wanted 2 inch from the manifolds and 2.5 inch from where the 2 inch came together and out past the axle with 2.5 inch.
The new system isn't as close to the brake fittings and cross member when bolted up, but the clearance is maybe 1/4 inch more at the fittings, and maybe 1/2 inch more at the front cross member than what the photos show. Still way too close for my liking. If this truck was a trailer queen it wouldn't matter.
I didn't get any pics of the temporary fix for the exhaust exit, I will get that tonight after I get the camper taken off of it.
