- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
So can I just paint over the WD40 with engine primer?
No, when you're ready to paint, hose it off with carb cleaner.
If you are going to paint immediatly, then you can blow dry and paint it ASAP. The rust process actually starts instantly all over again, as soon as it hits air out of the water, so it must be treated fairly quick. But I do the WD-40, let all that dry, then probably paint it the next day. But, paint will NOT stick to WD-40.
