Cummins engine swap?
74blazer
Reno
Nat
Blazer
has anyone swaped a cummins into a square body? im in the process of converting my neew 83 dually to a 12 valve cummins i have the motor mounted and trans bolted in just curious on the connection of the trans. has anyone performed this and is there any tips i can get?
74blazer
Reno
Nat
Blazer
do you know who the 4bt guy is
Yep, wildcatjason, that is his link in the post above. He put in a 4BT and made it a Full Tilt nose front end. Their is also a video of it going down the highway.
wildcatjason
Kansas
Jason
suburban
cummins 3.9 4bt
Who is that damn 4bt guy???
BTW, the other guy with the 6cyl has a Th400 behind his. Jason has a manual trans behind his. I'm trying to find the 6cyl guys thread, but his was built when he got here, so there isn't much tutorial with it, just Q&A about it.
wildcatjason
Kansas
Jason
suburban
cummins 3.9 4bt
Yes sir! Saw the cummins swap and thought I'd take myself a peak. I've had it in and out twice in the past six months due to the damn dowel pin that most pre 2003 cummins owners face.
wildcatjason
Kansas
Jason
suburban
cummins 3.9 4bt
Which tranny? What do you mean connection? Mount? Speedo? Driveshaft? Torque converter/clutch?
wildcatjason
Kansas
Jason
suburban
cummins 3.9 4bt
I've documented my whole build do I'm sure I can find a pic if necessary. Lemme know!
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
wildcatjason
Kansas
Jason
suburban
cummins 3.9 4bt
So I'm going to start a thread about putting Bugatti Veyron v16 in my suburban without any pics and then .....I'll let it die.
jodygraham64
