Converting 2wd SB to 4wd !!! Is it worth it???
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
Nice wheels man. If had money I would them for when I do 2wd to 4wd frame swap.
don't do a frame swap, bolt the 4wd hangers and crossmembers to your existing rails. much simpler that way.
For real? That's possible in a Squarebody frame? No cutting, welding or drilling into the 2wd frame to convert to a 2wd square to 4wd straight front axle??? I've been told the 2wd and 4wd drive frame are very differant and that is not worth the time and effort even if you are a good fabricator and welder that the best thing to do is find a 4wd rolling chassis? :popcorn:
Or are we talking about his 90 C2500 to be converted??? :popcorn: :popcorn:
It's been done many times, but you have to drill most of the holes. It really helps to have the donor frame so you have all the brackets and trinkets you will need, plus you can measure exactly where the holes get drilled. IIRC, the engine cross member does need modified slightly.
davbell22602
Bunker Hill, WV
I Dont
Have
One
I can solid front axle conversion kit for $599. All hardware is premade/predrilled for the holes on the frame.
I don't want to derail and hijack his Wheel/Tires thread, but it would be a great thread topic to start, cuz I'd like to get to the bottom of it once in for all. So I'll be moving some posts and starting a thread.
I have been interested in converting a 2wd Squarebody to 4wd for a long time. The little research I did, I came to the conclusion, its not worth it, and was advised to find a 4wd rolling chassis and transfer the 2wd Body to the 4wd frame and acquire a 4x4 cab hump or body lift so the taller hump is not needed.
If anyone has seen it done, or has done it, I'd be interested in what all is involved to do so. I also have a C20 88 Burb I'd like to convert to 4wd and I do have an 85 K10 truck wo motor and trans that would make a great donor to convert the Burb to 4wd if its the least bit feasible. I'll need lots of popcorn for this topic. So lets here all the opinions and experiences.
:popcorn: :popcorn: :popcorn: :popcorn: :popcorn: :popcorn:
Well then for your truck, being a 90 that OEM is IFS, I'd do that then. Then you can get rid of the weak IFS suspension and axle. No fabrication involved huh? Its all bolts in with grade 8 fasteners I assume? hmmmm I'd be interested in the conversion someday too. But for today and in this forum, I'ld like to see where someone did a 2wd to 4wd in a Squarebody. :superhack:
hmm, and it looks like its $124 for a Tcase crossmember too. Kinda getting up there in price. But, if you consider you are also getting a 3inch suspension lift out of it too, its still not all that bad. A bit pricey, but if its engineered right and bolts right it, and you want a Sraight Axle GMT400, then its probably the way to go. The cheaper way out would be the frame swap, but then you are not getting the lift and you have the dreaded IFS system.
I was responding to the SB swap question. But yeah, solid axle is the way to go on a new body 2wd.
It's another one of those things were everyone has there own opinion. The frame swap is simpler, but may involve more work overall. It also requires lots of buddies to help you out.
Most people don't recommend converting the frame simply because they hate cutting the frame rivets and drilling holes. But it can be done by one person without any help. It's really not a big deal if you are good with a torch and have a good drill and bits.
But, if you don't have a frame to swap or the wrong frame, like for example. Form what you are saying, I can take my 85 K10 pick up as a donor and convert my 88 C20 Burb to a K20 Burb with the right front axle hubs.
oneluckypops
Sedalia, Mo.
Luke
Dave ole buddy yes the kit is 599 but that is NOT a complete bolt on kit. Meaning that is NOT everything you will need.
Dont forget you will need.
1. Springs
2. Solid front axle from a FORD if you want to utilise the gm Transfer case
3. Brake Lines
4. Driveshaft
5. Hubs for a chevy
6. Possably will need to regear one or both of the differentials
7. crossover steering components
8. abunch of misc. that adds up
9. a case of beer
10. another case of beer
well all be dam it might just be affordable, given your 20% employe discount at wal-mart for the brake fluid and 2 cases of beer :Moon:
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
i was gonna say, what the hell? i didn't start this thread! :lol:
Garcjay
