Compressor delete
Georgeb
Wisconsin
George
K10 Burb Z71
You shouldn't need that for your square. Just take the belt off unless you have a serpentine belt setup.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Should work great. Used one on a Serpentine upgrade on a 70' C10 with no issues.
redneck_reed78
Spring Valley WI
Braden
R30, Suburban
So it's worth the $30 you think? Probably will do it regardless since it's cheap and easy any way, but could you tell any difference in the way it performed?
Georgeb
Wisconsin
George
K10 Burb Z71
Ya know, I was thinking....... You go off road with that girl right? Do you air down your tires when you do? If so before you go and scrap that ac compressor you could set yourself up with some onboard air........ We used to do it on all the squares we ran as junk yard wreckers to run our air tools. I am sure a little searching could find you all you need to know.
redneck_reed78
Spring Valley WI
Braden
R30, Suburban
Wow never heard of doing something like that but that is something to look in to for me. I'll do some googling!
I have been running the delete pulley for 2 years so far on mine. No issues yet.
aaron06
