Car doesn't wana start sometimes help !
labbetheking
Sweden
Daniel
Hi there! got myself a -78 chevy c10 350sb and sometimes she just "clicks" when i turn the key
even though the battery is 100% full and suddenly it can start turning and starts when i try to turn the
key once again. Feels like the car eats alot of battery when i try to start aswell because it can be alittle
hard to start even when she's warm.
Tried to put a extra ground to the engine from the minus pole on the battery but still no difference.
Could it be the ground from the startengine or the startengine itself maybe.
What's most likely to be wrong?
CSFJ
Sounds like the starter solenoid is going bad.
I realize you're from Sweden, but let's not offend our trucks calling them a car and giving it an identity crisis. You may or may not know USA is all up in crisis over transgenders these days and identity crisis. We can't help that, but we can help it with out trucks. :laughing1: Jus Kidding, Jus Kidding. I hear people here even calling their SUV a car and I want to correct them all the time but I don't. Being that you're in Sweden, you can't knock me in the head so I can correct you without harm.
My guess is going to be battery cables. Maybe even just the terminals at the battery posts. They may look clean, especially if they're side post, but if you take them off, you might see otherwise. The other problem that happens especially with side posts, it the bumps will dig into the soft lead of the battery post and eventually, probably from vibration, the bumps become loose. To correct that, simply loosen the terminal, turn the terminal about an 1/8 to 1/4 turn and retighten so it's grabbing a new spot in the battery post.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
You should check for voltage drop across the positive battery cable. If you're loosing voltage across the cable, it needs to be replaced. Otherwise, I'd suspect the starter motor because the solenoid's clicking. You can tap on the starter body with a hammer and see if you can get a few more starts out of it.
You guys are making sense suggesting the solenoid, but I'd still check those terminals first. Seen it a million times tow truck driving and doing jump box starts, especially the side posts.
dbarham78
