Caliper noise!!!!!!!!
charlesg
wisconsin
charles
k3500
Ok so replaced the pads, fitted them by bending the tabs, put some of that orange brake quiet stuff on and replaced the ds bolt slide with a thicker one and still getting banging noise when go over bumps with foot off the brake, thinking of putting shim stock under the bolt slide retainer, any thoughts?
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
A little lost here - DS bolt slide - ?
2WD, or 4WD ?
If 2w, wonder if there are some worn bushings in the upper control arms allowing them to pivot back and forth .
Got pics?
Thanks!
Britt
K201979
Winona, missouri
Hippie
350ci
Do you have the spring clips holding the inner pads to the pistons installed?
Rusty Nail
Rusty
350sbc
I'm with @Goldie Driver . Kind of.
There are only so many options for brake parts and you already replaced the little bushing....my thought was "maybe it's time to find a different bad guy"? I'm not convinced PLUS there's no pix.
Martin
Manitoba
Martin
Not sure if you have fixed your problem but if it is a 1 ton you have to shim your calipers or they will continue to make the clanging noise when driving. Once shimed they will be nice and quiet!!
charlesg
wisconsin
charles
k3500
how do I shim them??
Garcjay
