Cab Marker Light Placement
DertRyde
Atl, GA
Billy
C1500
V8
Just ordered the harness, thanks for the info, I should have started there.
Thunder
Colorado
D.
Chegny , to answer your question about the outside markers, I think that would be pretty cool. That's going to take some extra wiring. Too bad they don't make those lights in red. You could mount two to the rear of the cab also. Just thinking out loud.
Konas new ride
Alberta
Gerald
Those outside lamps flashing would be hella cool.. hmm my head liner and trim is out.. that's a interesting idea...
Edhard_Stark
Connecticut
Ed
Just out of curiosity, how do you guys fish the wiring in the cab for fitting the markers? I'm going from a cab with cab markers, to no cab markers. I'd like to mod the new cab to keep them, but I'm curious as to how I'd go about fishing the harness in it.
MadOgre
NA
NA
NA
NA
NA
X2.
MadOgre
NA
NA
NA
NA
NA
When I pulled my front fenders off I noticed that there is a small hole at the bottom front of the drivers windshield pillar. Im thinking maybe that's where you fish it down and then access the pillar from behind the dash ?
Konas new ride
Alberta
Gerald
The factory harness on mine comes out where the sun shade is mounted inside the cab. lots of room for the wires.. From there it goes down the drivers side post under the plastic trim.
MadOgre
NA
NA
NA
NA
NA
What about trucks that were factory with out the headliner ?
Konas new ride
Alberta
Gerald
no clue on that one.. possibly down the inside of the post.. Never seen one up here with out a liner or trim..
firebane
Calgary, AB
Curtis
Remove the visor and there should be a hole in the roof where the spring goes.
You would have to do A LOT of fishing but it would be possible.
MadOgre
NA
NA
NA
NA
NA
No what im asking/saying is that Trucks came factory with cab markers and no plastic pillar covers for the headliner so im pretty sure they did not have wiring running down the outside of the pillars for those trucks. ?
firebane
Calgary, AB
Curtis
There is a space about 1" or so between the roof inside the cab and outside the cab. Also the pillars are hollow not solid.
So when you drill the holes in the roof for the lights you can if your good fish the wires down through the pillar to hook them up.
MadOgre
NA
NA
NA
NA
NA
Exactly. GM must have wired trucks that way that came without the liner. I thought maybe they might have fed them down the drivers side rear pillar instead ?
Konas new ride
Alberta
Gerald
If your trying to fish wires in between the skins use fishing line (yes real fishing line) and a vacuum to suck the line across.. Then tie your wires to the line and pull..
EazyT
