Bvllsh!t on craigslist.
CSFJ
Should ask if there's any smoke damage. Lol
CSFJ
No, I was just looking for a wench. Not a winch or winch bumper.
Technically, you ca get a tug job from both. Just a different mess to clean up after the happy ending.
For spending that kind of money, you'd spend more, but I'd sure give alot of consideration to a 4L80-E instead. You'll have drive shaft and mounting expenses with the stand alone OD unit too. Do a 4L80-E conversion and be done.
4L80E swap isn't cheap either. I, too, want my trans to have an overdrive badly!! Lol
No It's not cheap. I mentioned it would cost more, but my thinking is, if you have $750 plus cost of driveshaft and crossmember mods, then for simplicity, I think I'd spend a bit more and go for the 4L80-E. Maybe even look into 6L80-E. How true, I don't know, but I've heard 6L80-E can be a stand alone unit too used on our older trucks.
If it could be done, I'd actually much rather just do a 6L80-E over the 4L80-E. Some interesting facts about the 6l80-E. Or at least it was to me. It does NOT have a 1 to 1 ratio gear ratio. The closest it gets is 1.15 to one for 4th gear. Another interesting fact, it has 2, yes 2 different OD ratios. .85 and .67. The reason for no 1 to 1 and 2 OD's, is to have a limited set of planetaries to make all those gears. The first gear is something in the 4:1 ratio. Talk about launching !!! And we like the 3.06:1 in 4L60-E/700R4? I'd love to have a 4.56 or 4.88 rear gear ratio and a 6L80-E.
Interesting info :) in my case, I've got time to truly plan and save pennies and such. Having the extra gears would definitely improve drivability by a significant amount!
Camar068
10 yrs Air Force
Lol now just figure out a cheap way to mate it up to a np208 and I'll do it!!
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
An interesting prospect for any Arklatex folks. Not beat to hell like some for similar prices and a cheap jumping board for someone who wants another square body project or wants to get into squares altogether.
http://monroe.craigslist.org/cto/5889165708.html
Andrew45
