Body mounts
87Oliver
Windsor, Va
what do you guys recommend for new replacement body and can mounts? I want to replace my 3 inch body lift with a 1 inch body lift and replace the mounts. Thanks
TubeTruck
East TN
Denis
Suburban K10
LQ9
Energy suspension for the actual mounts
87Oliver
Windsor, Va
Awesome thank you. Are the hockey pucks any good ?
eskimomann209
Modesto
Marcus
They’re just spacers. You still need the mounts. some people swear that poly sucks for ride quality. I have them I didn’t notice anythin negative.
But rubber ones are still available.
75gmck25
Northern Virginia
Bruce
I used poly to replace stock rubber mounts and it has worked well. I lubricated them when installed, but they still squeaked for a while and made creaking noises. However, once they settled in the noise went away and they are quiet now.
I bought them from LMC and I think they were Energy Suspension brand, but I'm not positive. If you check with Rockauto they seem to have the best prices.
Bruce
ali_c20
Austria
Alexander
C20, K5
I replaced my worn out rubber with rubber. don't know if there is any difference in ride quality when using poly or rubber. Poly should last longer.
Big Chip
Michigan
Kevin
C35
I used poly on my crew cab and it seemed to have stiffened the whole assembly, if that makes sense? It didn’t seem to have as much twist or something. It’s hard to explain but it could just be the difference between 40 year old parts and brand new parts.
Holl
Rich
suburban
I used the ORD body lift kit...it worked well
Joshua Keith
Memphis
Joshua
I’m wanting to do the same thing. Let me know if you can find the new bolts when you remove the 3” spacer. I’ve had some issues. Also, once the spacer is removed, is there anything that goes between the top bushing protector and cab/bed? I’ve seen some that have a square spacer in between.
1987R30
