Axle swap for gear ratio
Good Job there on the clean up. :waytogo: Certainly a set of axles worth all the effort.
fallguy
Minot, ND
Jamie
Silverado K10
This is the weekend! Hubs are done. Rotors to be turned and assembly to begin....
JH
Sent from my iPad
fallguy
Minot, ND
Jamie
Silverado K10
Strange looking setup...new rims being married to 35x12.5R15 BFG AT's
Axles with new aluminum covers and assembly started.
Drums married to hubs...new bearings/seals/races
Axle tubes were full of dirt. Cleaned out. Spindles were stuck on. Spindle bearings rusted solid and impossible to remove...getting outside help for that removal/replacement process.
Nice !!! Certainly a worthy upgrade. It'll be a totally different truck when done.
fallguy
Minot, ND
Jamie
Silverado K10
Axle dropped.
New axle in place.
Front in place.
Final product....can't drive it yet though...rubs BADLY in front (only a 2" lift on now). Sigh, 4" lift coming tomorrow.
Driver4r
Nebraska
Trevor
k10,c20
Sweet, cant wait for pictures with the 4". Im having a hard time finding a truck on 4" lift with 35's. I need a picture to show me what my truck will set like.
77 K20
Montana
K20 5" lift
HT383 fuel injected
Looking good...
but ditch those cinder blocks! Obviously they worked for you- but can crumble in an instant. A friend of mine used to work for the fire department and had stories of body recoveries from failed jacks and broken cinder blocks.
Looking good...
Not only YES, but FUGG YESS !!! Do NOT use cinder blocks for jackstands. NEVER. I personally knew a guy who died. 2 wheels up on the curd, 2 wheels on cinder blocks. 1 block broke under the left front wheel and killed him almost instantly. Thankfully he went unconcious instantly, died just as the medics got there, and pissed and **** his pants right there.
2 weeks ago in MWC, OK an old guy's garage door was left open. Neighbors knew this guy never did that. About 9:30pm they went over to close his garage door for him and found him dead under his car with broke cinder blocks.
TRUE STORIES. I am sure if you went to News9.com, you can still find the MWC, OK story. It's still pretty fresh.
Driver4r
Nebraska
Trevor
k10,c20
Looking good...
Fill the cinderblock full of concrete, then put a peice of 2x6 or 2x8 over the top between the stand and the block.
Sure, you COULD do that. But for the risk??? And the cost of some some 4x4's or 4x6's that you can find anywhere for FREE. Concrete CAN crack and break out too. Even a cinder block on the stonger edge just isn't worth your life IMO.
Maybe it's just me.:shrug: I wont fuggin risk it noway, nohow and maybe that's because I've been close to a guy who died from cinder blocks and curbs. Curbs I'm good with, but really lumber for FREE or Jackstands is best.
tanz45
Hopewell, PA
If you do use them, have to atleast use them in the proper orientation.
Holes top and bottom.
Personally, i bought the HR 12 ton stands and use some 8x8's and stack like lincoln logs.
fallguy
Minot, ND
Jamie
Silverado K10
Ok, other than too many cinder block orientation comments (blocks were changed shortly after taking pic due to realizing they were placed incorrectly)...the job is done.
Steering creaked constantly and was hard to control when I hit any bump.....removed driver tire, drive shaft and housing...new upper & lower ball joints...problem solved.
Leaking fluid from front differential....pinion seal bad. Replaced that today too.
Tightened steering box gearing....drives like a different truck!
4" rough country had to be added to clear tires after this pic was taken....toooooo much rubbing otherwise!
JH
Sent from my iPad
JH
Sent from my iPad
So where are the new pics with the 4in lift? huh? Where they at??? Git'em Up !!! :adminpower:
fallguy
Minot, ND
Jamie
Silverado K10
With 4" RC lift, but from the ride im experiencing...im thinkin i chose the wrong lift company....very rough/bouncy...my wife now hates riding in my truck cause its so bad....no clue what to do about that....
PapaBear8486
