Another NP203 Question
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Agree, I was referring to shifting slop I can feel in the driveline when going D-R and back.
you by chance have a detroit locker in one of the axles? some people are thrown of by the chunking engagement they can have.. unless of course this slop is a recent onset for the truck.
Agreed, a non-converted case would fit the bill here.
And as far as t-case swapping goes, you're stuck with a 203 or a 205. Anything else will require a longer output shaft in the trans.
MtBraun
South Dakota
The rear is an stock open differential. The front is probably stock too...but not positive on that.
MtBraun
South Dakota
get a regular non converted 203 and throw it in. Should not matter for a snow plow truck that barely drives much of a distance
good thought. Or could I remove the current worn out part time kit from my original transfer case? If I can't do that and have to source an unconverted NP203, what do I do about my front locking hubs? Just leave them locked in?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
In 4x but unlock them when not, even remove the front driveshaft in spring and summer with the hubs unlocked.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
Unlocking the front hubs in a non-converted 203 will allow the truck to roll away in park if on an incline. The rear portion of the tcase has a differential similar to what you find in an axle.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Oh my bad my black eye for he day:boxed: sorry @Matt Braun for mis information.
Rusty Nail
Rusty
350sbc
This.
That conversion is of the devil. Exorcise your truck and be rid of it forever!
I think my truck is not converted but only has locking hubs...I leave it in 4H ALL THE TIME, hubs locked.
It drives better with the hubs locked and i like it gooder...
yevgenievich
Viktor
sad
very sad
less sad
As mentioned leave hubs locked. Depending on the conversion kit it has, but I believe you would still need to source a non converted 203 to undo the conversion
... but I believe you would still need to source a non converted 203 to undo the conversion
Yup, and there are parts variations between the different years.
MtBraun
South Dakota
Well, what about putting in a new mile marker kit? Looks like an easy enough job and a lot faster and cost effective than sourcing an unconverted 203. I know these aren't good long term kits but for the amount of mileage we are putting on what would it matter?
This.
Well blow me down! I've heard that leaving it in 4WD all the time can damage the Tcase. I have a non-molested 203. Have I been misinformed? Please edumacate me.
yevgenievich
Viktor
sad
very sad
less sad
That depends on what exactly is wrong with the existing unit
CSFJ
The 203was designed to be a full time 4x4 case. That's why it has the extra differential in it, to allow the front and rear wheel sets to spin at different speed, like the open diff in an axle. The other cases will get damaged if driven in 4x4 for extended periods on surfaces like pavement. They don't have the extra differential in them, so if the wheels can't slip, it put more strain on the case.
MikeD
