Aftermarket Cam for stock 350
Marcus
Gans, Ok
Marcus
GMC K1500
Have a fully stock 350 4 bolt main. Looking into buying a rebuild kit that comes with a stage 2 cam. Curious on what everyone thinks about the stage 2 cam in a stock 350 4 bolt main. I’m not looking to get 400hp or anything crazy. Just a little something to put some ump into it. What do y’all suggest?
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Thank you for submitting your question.
I suggest you give us more info regarding your needs, equipment and ****, heads, gear ratios.
ali_c20
Austria
Alexander
C20, K5
Depends on what you want to achieve: low end torque? More horsepower at high rpms? Choppy idle?
Marcus
Gans, Ok
Marcus
GMC K1500
1985 GMC K1500 with 3.42 gears. Everything is bone stock. Only thing I’m gonna do to it is take all the smog crap off. Take apart and rebuild it with all new gaskets, pistons, rings, cam, timing chain, freeze plugs, etc etc. I just want a little more hp and a deeper growl. Something to wake the weak low hp engine up a little
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Sadly there is little that can be done with the smogger heads.
If you're putting in new pistons you can certainly raise compression. Nothing crazy requiring high test, but a step above stock.
If your bottom end is rouge and the crank needs to be reground, you might consider a stroker engine kit.
Do you have an engine builder close by?
Dave 84
Arizona, glendale
Dave
So I would do a cheap set of flat tops and cam!
Marcus
Gans, Ok
Marcus
GMC K1500
I know of very reliable engine guy 10 miles from here. I’m know I’m taking the heads and crank to him. The engine is not the factory engine for this truck. It originally came in a 1975 Nova police car if that changes anything. I just want it to run good, breathe good, and bump a little hp and tq. Nothing crazy.
Marcus
Gans, Ok
Marcus
GMC K1500
This is the kit I have been eyeballing. Just don’t know quite enough about all of the specific parts and numbers.
Marcus
Gans, Ok
Marcus
GMC K1500
Still trying to figure this out. Any thoughts on this kit? Should I get something else?
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Oh well you have a great start. I was wondering because you mentioned you had a 4 bolt block... which I don't think you would see on an '85 smogger engine.
If you're springing for new pistons you will be taking the block to your engine guy too. You'll also want your block hot tubbed and scrubbed and your engine builder SHOULD be able to do this for you.
If you're going this far including getting the crank reground, I would seriously consider a stroker engine kit with the bigger crank.
Marcus
Gans, Ok
Marcus
GMC K1500
I know that I should send the block off to have everything done but I don’t have the $$ to do everything from inside out top to bottom.
Marcus
Gans, Ok
Marcus
GMC K1500
Well I’m trying to do this on a budget to have a running engine that doesn’t leak, lack power, or have smog crap on it for now. I know for a fact that the block is solid but what is unknown is the cylinder walls and rings. Just trying to do everything right as possible on a budget. Hard thing to do these days
Oaasport
Justin
Suburban V10
@Marcus how much is your budget? This will allow us to further help you with getting some more go. Headers, exhaust, intake manifold can add a little power and give you that growl you want. It all comes down to budget.
Marcus
Gans, Ok
Marcus
GMC K1500
My budget is like $600. The engine runs. Just has oil everywhere which I’ve cleaned the outside really well. Just want it running for now but I want a better cam in it cause it doesn’t have a lot of hp. There’s been no loss of compression at all. Just not quite enough hp and growl to it.
TheDustyDresser
