Frankenchevy
Proverbs 16:18
- Jan 3, 2018
- USA
- Jeremy
- Square
- CUCV
- Small
I like to pull the plugs and turn the engine by hand. having the plugs out also helps to find TDC. I don't like to bump the engine with the starter, I like to watch the valve slowly close so I know its exactly where I want it to be. i find it easier to find zero lash with a primed lifter. pinch the pushrod with your thumb and index finger and roll it back and forth like (sorry for the reference) a booger as your tightening the adjuster down. as soon as you feel it start to drag you're at zero lash. from here, opinions differ on how much preload from 1/2 turn to 1 full turn. I've always been told a slappy valve is a happy valve, which is referencing an older style valve train. the point is still the same, better to be a little loose than a little tight. mine usually end up 1/2-5/8 once everything is locked down. make sure the rocker arms, lifters and pushrods are clean so that you can feel the drag accurately.
good luck
good luck
