89S's Pull A Part Thread
Thats the valve you need.
Son of a bitch, the last one I looked at. I know exactly which truck it is in. I'm heading there Saturday. You need anything dude let me know by the end of next week. I am going to be grabbing any connectors and harnesses and **** like that I can find.
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Naw...mine is running great since I installed that new small cap dizzy and coil.
Look for BPEGR on the vac stickers, thats what you be needin.
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
mmmm id love one of those heat only setups
thaddybob
MN
Thad
I wouldnt mind that grill of your arent taking it and shipping isnt outreagoues.
You know I just spent like 10 minutes trying to find these for sale to get an idea on shipping. I can't believe these are not around anymore. JCW and LMC always had these. :wtf:
Go take a look at yours again, IIRC, all 10-20 series trucks mount like that on the left rear.
Did any of those Burbs or K5's have a tailgate window? I really REALLY need the metal rail that pushes onto the bottom of the glass.
I'll go take a look now...
And I will keep that window piece on the list for me Saturday brotha. :D Does it matter which one it is? Or electric or manual? Does it pop right off the glass pretty much?
Where do you see it on that sticker?
You are right, I just stuck my foot in my mout. :roflbow:
It doesn't matter which it is, as long as it's still somewhat in one piece. Unless somebody has glued it on, it basically is a press fit on the bottom of the glass. It can be worked right off with a block of wood and a hammer... or just hit the glass with a hammer, but that's wasteful, lol.
And thanks buddy :)
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
... and it's a good idea to check it once in a while. Took me a long time to track down a mystery clunking sound to a loose shock & broken mount.
Dang Sky! :wtf: Did you weld that or have to replace it?
Here is the running list so far:
BPEGR Valve - 89S & spares
Prom Chips from 7747 - spares
Intact factory vacuum hoses and harnesses/plugs 89S & spares
Rear door ladder off conversion van - 89S
Jeep Shafts - 89S & spares
K5 & Burb rear lower window channel - Bucket and spares
Any engine and cab sensors and switches - spares
2 non a/c heater housing assemblies/controls/harnesses - 89S & Smurph/spares?
Clutch and brake pedals if hydraulic - hotrodpc
Tube grille - Thaddybob
3 factory coolant reservoirs - 89S & spares
2n'd row burb seat piano hinges - 89S
dashboard light sockets - spares
Single square headlight turn signal housings - spares
Aftermarket A/C unit - sell?
Heat riser tube - 89S
Intake manifold heater hose pipe or fitting - 89S
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
Rummaging around the garage, I found a 1.5" x 1.5" square washer that was 1/4" thick and had the correct size hole in it. Perfect. The problem is that's really close to the fuel tank, which I didn't want to drop again after recently doing the fuel pump.
Took it down to the local welding shop and asked if they were willing to weld it onto the broken mount. They were, so I beat a hasty retreat to the donut shop across the street and munched on an apple fritter while waiting to see my truck explode into a huge fireball. Needless to say it didn't, and they only charged me $20.
Useenamez
