- Dec 7, 2010
- Southeast PA
- Paw Paw
- Chevrolet Tahoe LT
- 5.3, 4WD
7/32 socket for cap screws and screws holding the ICM under the dist. Coil mounting brackets need to be swapped from old coil to new on. Factory unit has aluminum rivets holding the brackets to the coil, they grind off very easy and the brackets pop off. This coil came with the new screws but I did not realize until after I installed some I found in the garage. Used loctite on them also, and you got to make sure you install the brackets the correct way. One bracket is slotted so you only have to loosen one mounting bolt, and remove the other.
The new ICM came with a small packet of silicone to apply to the heat sink.
Towards the end of the pics, that white wire coming out of the coil to a black connector is not hooked to anything, anybody know what that is for? Tach hookup?
