87 v30
Mobius
Fayetteville, AR
c10 Heavy Half
350 SBC
FYI, a 285/75/16 is almost 33” tall and about 11.25” wide.
TheFishBox
OR
nick
v30
6.0 ls
Does anyone have info on how a 235 85r16 will work vs the 265 75r16? From what I have read the 265 will haul better and they are slightly wider which I think will look better. Will I have any running issues with these tires?
yevgenievich
Viktor
sad
very sad
less sad
A bit worse mileage is the only downside that I have experienced
Crispy
Carbon County, Pennsyltucky
Suburban V1500
tiresize.com has a comparison tool that visualizes the differences between two tires. Its helped me a lot in the past.
https://tiresize.com/comparison/
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Didnt know that, gonna have to check it out.
Yeah if you pick a tire and hit the specs tab, it gives you a chart with other sizes close to the one you’ve picked.
Craig 85
Nashville, TN
454/TH-400/NP205
For reference, here's what 265's look like on a stock K30. There basically the same height as a 235, but are an inch wider. They may look better with your aftermarket wheel width.
yevgenievich
Viktor
sad
very sad
less sad
I had 235 on the front and 265 in the rear for couple of weeks. Picture for reference.
TheFishBox
OR
nick
v30
6.0 ls
thanks for the pictures. Do you think you could get away with a taller tire or would you have rubbing issues?
yevgenievich
Viktor
sad
very sad
less sad
One inch taller should clear from what I could see on my v2500, but additional mileage and performance hit was not worth it to me.
TheFishBox
OR
nick
v30
6.0 ls
Does anyone have experience with the stt pros?
Taco main chew
