8 lug swap worth the effort?
K10 DELUXE
Missouri
K10 custom deluxe
Bone stock 350
I have a chance to pick up a set of 3/4 ton axles with 4.10 gears for $300. The rear is a 14 bolt FF and the front i am assuming is a standard 10 bolt because I couldn't find a 44 or 60 stamped on the housing. Just wanting some opinions on if they are worth the money and its worth my time to swap out my 1/2 ton axles. Thanks!
8T6K5
AZ
L98 350 TPI
...the front i am assuming is a standard 10 bolt because I couldn't find a 44 or 60 stamped on the housing.
Upper Right...
K10 DELUXE
Missouri
K10 custom deluxe
Bone stock 350
That's where I was looking and I didn't see anything that would tell me that its a Dana....that and the diff cover is rounded like on my 1/2 ton 10 bolt
marks86
Latham, NY
Mark
12v Cummins
you need to ask yourself do you need more than a half ton truck
not sure what you really do with it but a FF rear is the bees knees all you need is a dana 60 and you have to much strength, but like I said if you just tow your 20ft boat around I think a FF rear is an overkill
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
Has a lot to do with amount of lift/size of tires you want to run. Bigger brakes on the bigger axles sure help stopping a truck with bigger tires. If you plan on going big you should get them. 35 or 36" tires and down would be fine for the 1/2 ton axles but I wore out a shitload of u-joints, and broke an axleshaft, and exploded a front carrier with the 1/2 ton set up with 38s.
Driver4r
Nebraska
Trevor
k10,c20
If your staying factory height, My truck had 4.11's in a 12bolt/10bolt setup(on 32" tires). And those gears had no problem rolling my truck around. I could also smoke them pretty good :D
MrMarty51
Eastern Montana
Martin
Also,if You are planning on changing over to the 3/4 ton springs be prepared to move the rear spring hanger brackets back to the next hole.
Now I need to go get Me some grade eight bolts and self locking nuts to put it all back togehter again.LOL
chevy-lvr
