Got fooled by big hubs....
Blmpkn
Maine
Will
Pulled a pair of axles out of a beat up half ton, a 14bff and what I thought was a dana 60 (huge hubs, 8 lug)
Whelp, upon closer inspection it's not a dana 60. Its gotta be a 44. Bummed that I got duped by the big hubs... but whatever... the pair were cheap enough and its DEFINITELY a ff rear lol.
Is the big hub 44 really weaker than the small hub 44? The truck is going to have 35x10s on it and get wheeled occasionally.. but nothing crazy, and I'm pretty easy on the skinny pedal.
The budget on this thing is getting blown out of the water, naturally.. lol.. so I'm pretty stuck with running it regardless. I probably wouldn't be able to afford to re-gear my current 10 bolt to match the 14 bolt this year unfortunately.. so I'm hoping this big hub axle is up to the task at least for the meantime.
John-Ryan
John-Ryan
V20
I have a big hub Dana 44 with the spicers from a 73-77 truck on the front of my Burb. I wheel and trailride just fine on 37s. I tow my enclosed shop trailer a few times a month and keep everything lubed and torqued down. I would like a Dana 60 but what I've got has worked so far.
Blmpkn
Maine
Will
Thanks for the input. Is your 44 pretty factory or have you upgraded it at all?
John-Ryan
John-Ryan
V20
All factory still. I've been keeping an eye for spicer parts for the locking hubs, they are hard to come by. For instance on ebay there is a factory gm set that is used in the same condition as mine for $500..they must be good!
Termite_Delight
Lanark Ontario Canada
K2500 K2500
350 L33
I have a pair on my 75 K25, it would be nice to find new chrome covers.
Blmpkn
Maine
Will
What parts interchange with the "regular" 44?
Like.. shafts, bearings, brakes? Is there a master thread somewhere on the d44?
I need to figure out what year axle I have so I can start picking away at making sure its road ready
thanks again!
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
thanks again!
73-78ish is the years for a Dana 44 front axle
If you want to know the year
1. Look for a tag on the diff cover, under a diff cover bolt, sometimes they're there, sometimes they're not.
1. Look on the top of one of the axle tubes, there's a BOM number which can be looked up. It'll tell ya the year.
Should be the long side, which is driveer side for a Chevrolet.
On the small bearing 44, I think shafts, carrier, gears and maybe knuckles interchange
The "big bearing/big hub dana 44" I believe features larger bearings (obviously lol), a larger hub, larger brake rotor size as well?
Strick
Dunn, NC
Harold
C20 Crew
I've got the same setup under my 74 K5. I pulled the factory Spicer hubs and spacer and put a set of external Warn hubs on a couple decades ago. I always look for the seam on that "big hub" setup as that and the hoghead size of the differential are a dead giveaway along with the knuckle ends where the kingpins go on a D60.
The 44HD has bigger wheel bearings on the spindle but all the other components are the same a half ton stuff I do believe. The advantage to running these is that usually they are 4.10 geared and have the 8 lug wheel pattern. With larger wheel bearings this allows for running larger wheels and tires. I've had 36 Swampers under mine for years with no issues.
Strickland
theres more years but they significantly change design in 77-78 from what I could research
well, sorta... its weird
dvdswan
Port Orchard, WA
Dave
You didn't get fooled. You've got a Dana 44 HD.
Just remember when looking for a D60 to look for the kingpin ball joints. 4 bolt caps on the upper ball joint.
SquareRoot
Late to the party, but I got fooled by big hubs once.............wait.....what................oh wrong party
I was drunk and married "big hubs". Took me 15 years before I realized I was fooled. Happens to the best of us.
John-Ryan
John-Ryan
V20
Grab some pb blaster and a wire brush for the axle and differential. The numbers are there just covered up.
Blmpkn
Maine
Will
Awesome! Thanks everyone for the input & info.
504SquareBody
