- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
Are parts exchangeable between the 8.1 and the 4.8/5.3/6.0?
That's a Big NO.
Trans mount was slid back until the front cross member holes lined up with the rear holes in the frame. Drilled the rear holes in the frame(4), stretched the trans mount holes about 3/8 in and bolted it in. Shorten the front drive shaft about 3.5 in.
Swapping from a th400 to a 4L80E is pretty easy. Trans can be bought fairly cheap now. Biggest headache would be the controller(cost as much as the entire engine/trans harness from Howell). Or go manual shift.
Interesting, I was planning on manual shift myself so thats no problem. Man, your build thread here just made my life a hell of a lot easier! You know there does not seem to be one definitive swap guide for 4L80Es into squares? I think you may have just fixed that problem...
So I guess you could say I like them. Still have a few bugs to work out, and hope to tweak the pcm for a little more mpg. But 3.73 gears are the main reason for my bad mileage.
Hit me up if you have some questions, happy to help of I can.
So what gear ratio do you think is going to improve your mileage?
You'd be another that can put some input into a 4L80-E swap thread when the time comes. Stay tuned for that.
My motorhome has a 4.56 gear, weighs 14000 lbs, and gets almost double the mileage. My truck weighs in at 8500 lbs and when it locks the converter in 4th gear at 60 mph, my RPMs are at about 1800. I have been advised that a gear swap to 4.11, 4.56 would help my truck.
I have 2 91 crew cabs that have factory 4l80e trans. So when the time comes for for the trans sticky, I will do what I can to contribute.
