'77 throttle pedal position sensor.
RADustin
New Orleans
Dustin
C20 Crewcab
I bought a '77 crewcab(just the cab, silverado trim) and while disassembling it I noticed it had a little linear potentiometer the bumped against the throttle pedal. I assume this was some sort of early style TPS.
Is this what it is? and what was it used for?
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
If it's what I think it is, then I'd answer sorta because it senses accelerator pedal position, but it's not for the throttle. It sounds like the kickdown switch for a TH400. When you stamp down on the pedal trying to pass someone, that switch tells a solenoid in the transmission to kick it down to second gear.
Turbo 400 kickdown activation switch. Pretty much just a WOT switch. Send a signal to the solenoid in the transmission. Should have an orange wire going to it.
RADustin
New Orleans
Dustin
C20 Crewcab
that's it. I thought turbo 400 used the vac modulator for kickdown??
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Nope electrically activated kick down. I used to wire it to a relay from the red button on my shifter. All you need is a momentary switch. I used a relay and switched the ground' the wires in shifters are pretty small.
RADustin
New Orleans
Dustin
C20 Crewcab
alright.
Makes sense. I'm learning...slowly.
Thanks Gents.
74 Shortbed
It does have a modulator but it has to do with shift points not the kickdown.
The governor and vac modulator determine shift points. The throttle switch will override both.
aaron06
