6inch vs 8inch suspension lift
Moats31
Linesville, pa
C10 and k10
I was going to go 6 inch, but might of found a set of 39.5inch boggers. I know the 6inch is pretty much bolt on and I an use my existing drive shafts. If I go 8inch what would I have to the steering, drive shafts.
83 gmc c10
- 350/a883
BUILT NOT BOUGHT
It's going to be about the same really. While the stock shafts probably fit with a 6 inch lift, they will be too short for real offroad use. I run a stock front shaft with 4 inch lifts, it is just barely long enough for how I use the truck. I ended up having a longer rear shaft made for my Burb too. For steering you would need a raised steering arm and a dropped pitman arm. Unless you want to convert to crossover steering.
Generally an 8 inch lift will ride a bit rougher too.
nvrenuf
Mobile, Al.
Yep, count on driveshafts and steering for either kit. You'll also probably need brake hoses.
Definitely better off going 6" and trimming some.
Moats31
Linesville, pa
C10 and k10
I'm going to have a 2inch body lift as well because of the c10 body being put on a k10. I'll need the room for the t case! What's the biggest tire I could fit with a 6inxh suspension and 2 inch body? Pictures would be nice...
83 gmc c10
- 350/a883
BUILT NOT BOUGHT
Moats31
Linesville, pa
C10 and k10
How does cross over steering work. And how could I make it or do you buy it? And where do you get your drive shafts made?
83 gmc c10
- 350/a883
BUILT NOT BOUGHT
83 gmc c10
- 350/a883
BUILT NOT BOUGHT
I have a mock-up pic of those tires on my Blazer, I'm not sure what the lift is though. I know it's 6" at the most. I just have shafts made/modified at a local driveline shop, they know what they are doing and they are very fair priced.
Moats31
Linesville, pa
C10 and k10
I wouldn't mind taking mine there if they don't work!
83 gmc c10
- 350/a883
BUILT NOT BOUGHT
Moats31
Linesville, pa
C10 and k10
I used to work at worthington cylinders, so I know the area pretty good!
83 gmc c10
- 350/a883
BUILT NOT BOUGHT
The place I use is called Driveline1, they are on the SW side of Columbus.
Moats31
Linesville, pa
C10 and k10
Thanks I'll look into that.
83 gmc c10
- 350/a883
BUILT NOT BOUGHT
andrewabird
