JOHN MEADOWS
- Apr 26, 2018
- tennessee
- john
- 1/2 ton custom 4x4
- 350 tbi
I just got a 87 custom 4x4 with a 350 tbi. The problem i found when you start it on a cold start it wants to surge to the point that it will idle up and down til it almost dies and then back up. After it warms up it seems to run a little better but you can still hear the surge. While the truck it appears to have power as it should. While at idle , it seems to run very rich. Since having the truck i have put on coolant temp sensor, iac , fuel filter, and rebuilt the throttle body. Nothing has helped it. Id like to keep it like the truck came, but im to the point of saying heck with it and putting a carb on it ( but really dont want to).
While doing this , I havent found a oxygen sensor on the exhaust and i believe i found the plug for it but it doesn't have one there. I have also noticed near the bottom of the front of the motor what i believe is a crank postion sensor that has nothing plugged into it. Did these trucks even have that on an 87? I have checked the codes and nothing dealing with oxygen sensor was showing. SO if someone thinks they can help me with this issue i would greatly appreciate it. Also would like to say that I'm no professional mechanic so bare with me please .
